What can be done about Phoenix AZ summer heat prius?
Discussion in 'Generation 1 Prius Discussion' started by boostedsil40, Aug 8, 2019.
  1. boostedsil40
    boostedsil40 Junior Member
    24
    AZ
    2002 Prius
    Hello everyone,This is my GF 2002 prius,The car MUST be parked in the shade at all times and when not it must be covered by a tarp,failure to do so results in the turtle light coming on and if driven with turtle light the red exclamation will come on and the car is done till it cools down,The red exclamation happened twice but the turtle light is more common.She drives it like a baby to help the battery but Im in need of ideas on how we can keep this cabin and battery cooled better?she has ac cranking when driving and so far the only time these issues happen are when the car sits in the sun but its still teetering on that edge of too hot with summer getting bad.
    I checked the fan and it was clean,My only ideas now are to add another fan or something?or make a type if intercooler or swamp cooler effect with ice water.
  2. Leadfoot J. McCoalroller
    8,088
    7,567
    Pennsylvania
    2018 Prius c
    With that much environmental heat and an old car there’s only so much you can do.
    Maybe consider a remote starter, so the AC can get a head start?
    If it were me I’d probably just accelerate my plans to trade up to something newer.
  3. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    You have checked the inverter pump to make sure it is still working, correct? To be absolutely sure the problem is caused by too much heat in the cabin, I would think it would be worth your while to have the codes read by a hybrid compatible code reader.
    51,932
    tint the windows and window shades?
    is the battery original?
  5. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    I have my PRIUS in the HOT Florida sun=NO ISSUES
    It's not the summer heat...It's your battery- HAVE IT CHECKED OUT
  6. ronlewis
    ronlewis Active Member
    985
    196
    texas
    2001 Prius
    What he said^^^
  7. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    It's likely not the battery, tho it could be the battery fan. Needs to be checked out.
    More likely, it's the inverter coolant pump. Not expensive to fix if you can do the labor yourself. Mine had the symptoms you describe, on a road trip. It cooled off and resolved, but I ended up replacing the pump and never looked back.
    And, btw, never replace the inverter coolant pump with a wrecking yard/used one. They are a wear item and good replacements are available from Amazon or Rock auto.
