What can I add/install onto the Prius to reduce highway air drag/vortex movement?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by h1ph0panonymous, Oct 24, 2023.
Tags:
  1. h1ph0panonymous
    257
    36
    Before I bought this 2014 Prius 4 model a month ago I was driving a 2017 Ford Fusion SE for six years, nothing special, no spoiler, no fins, just a bullet shaped car that never caught air drafts on the highway unless I was stuck in traffic 10 feet right behind a semi truck catching it’s box shaped air vortex draft or a 50 mile per hour wind gust which would make all traffic shift positions slightly.
    But with this Prius I have now I feel like I’m literally catching every slight gust, every cars draft from behind them and BESIDE them on the highway. I don’t mind it overall but it makes me looks like I’m driving drunk or distracted which I don’t want if cops are near by.
    What can I add to my car; side mirror fins, rear roof fins, underbody fins, a spoiler, etc...which one of these actually stops the effect I’m experiencing on the highway?
    maybe it’s because the car is 1000 pounds lighter than what I used to drive idk
  2. Leadfoot J. McCoalroller
    7,988
    7,466
    Pennsylvania
    2018 Prius c
    That's a bingo!
    The longer wheelbase of the Fusion also helped with high speed handling.
    h1ph0panonymous likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    Tires make a difference also, including something as simple as inflation pressures.
  4. bdc101
    bdc101 Member
    250
    89
    usa
    Your Prius is only a couple hundred lbs lighter, but the wheelbase on the Ford is 6 inches longer. Additionally, it's tires are much larger (30mm or 40mm larger width) and probably made more for general roadholding than efficiency. Fins aren't going to do anything to keep you from being tossed about by gusts, I would get bigger tires is probably the best suggestion. Or a good alignment. More toe in and more camber would help with dynamic stability, at the cost of efficiency.
  5. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Dynamic stability is complex and affected by a variety of factors, including aerodynamic stability (surface area, side force, yawing moment, yawing moment change with yaw angle), suspension and tire factors, and vehicle loading.
    You can measure stability using steering angle as an indicator. I found that shifting a 300 lb load moved the center of gravity of my car 3 inches, and this change was measurable in the steering angle in a constant crosswind, logged on an OBD scanner. Read more here. More on aerodynamic stability in general can be found in Julian Edgar's Vehicle Aerodynamics: Testing, Modification & Development (2023).
  6. bdc101
    bdc101 Member
    250
    89
    usa
    Only question is, how does one go about finding a constant crosswind? And verifying that it is constant for the duration of your test?
    I will be happy to read your link later though - ex-FSAE member here, now an advisor for the local solar car team.
  7. Grit
    Grit Senior Member
    6,563
    4,222
    Wilkes Land
    I have side and rear side splitters, they work great stabilizing straight line driving.
  8. h1ph0panonymous
    257
    36
    You made those thingy-ma-bobbers on the bottom skirt front and rear?
    looks cool, I see you lowered it too but winters coming, not trying to sled around.
  9. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
  10. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
  11. Vman455
    539
    556
    The Middle
    Oh nice, I thought about joining FSAE but Solar Car seemed more up my alley.
    I check weather forecasts and wait for a day with suitable predicted conditions, build everything I'm planning on testing so I can quickly install or remove it to shorten test time to a minimum, and use an anemometer to check wind speed. Depends where you are, too--here in the flat Midwest in the winter, it's relatively easy to find suitable days for crosswind testing (windy but not gusting); where I grew up in mountainous Washington probably not so much (although I've never tried it there). I've abandoned many a test when conditions changed. By its nature, testing in the real world will be subject to variable conditions, so when I do things like coastdowns I also run statistical confidence tests on the results.
