What choices to fill our tires with?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ZC1, Jun 16, 2008.
  1. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Okay, we've all seen it in Tire shop advertising...
    Don't be old school by using air, rather be tech savy :nod: by filing up your tires with *gulp* :eek: Nitrogen.
    So what really are the benefits of nitrogen filled tires?
    Will my tires eventually explode :flame:like the Hindenberg?
    Or should I be using Helium instead, so my car floats :bounce:down the road?
    Curious minds :confused: want to know.
    ZC1
    (this really looks like a test of icons post)
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Don't start this thread again. Most of us don't have the strength to do it all over again.
    Try a search and you will find more posts about this topic than you could possibly ever want to read.
    Tom
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The Hindenberg didn't explode. A static discharge ignited the doped fabric covering the airship. Notice that the ship settled softly to the ground.
  4. ZC1
    711
    Metro Detroit
    Sorry Tom.
    When asking the question, similar questions didn't show up.
    I failed to use the search this time.
    My bad.
    Question is closed, search instead.
    ZC1
  5. jammin012
    jammin012 The man behind The Man
    510
    Cali
    Whipped Cream. It softens the bumps and if you get a blowout you wont be stranded without food.
  6. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    Pressurized with Nitrous Oxide laughing gas for obvious reasons. :)
    Freebie: No Nitrogen pretty much doesn't react or burn at all.
  7. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    "don't waste your money"
    unless your serious about racing
  8. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    Who isn't serious about racing? Isn't that why we all bought the Prius? :D
  9. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    In order of preference:
    1) Fairy farts.
    2) Nitrogen.
    3) Raggedy ol' gas station air.
    I fill with #2 for free at Costco. Don't tell me it doesn't make a difference. I go several months before it even drops 1/2 lbs. I seriously think I lose more pressure with all the checking . . . gott'a - stop - doin' - that! :der:
  10. richard schumacher
    7,663
    1,038
    United States
    Could be :_> Once a month or when the average outdoors temp changes more than 20'F is often enough.
  11. GatorJZ
    GatorJZ Member
    285
    17
    1) Nitrogen
    2) SCUBA tank air
    3) all other air sources
  12. hiremichaelreid
    451
    I
    So, is there no way to get pressure from the TPMS ? Or can it only show pressure is low ?
    Perhaps you cold just over-pressure your tires, set the TPMS and lower them to within 1 PSI of triggering ?
  13. Sufferin' Prius Envy
    3,998
    I AM the TPMS. ;)
    2005 or earlier didn't have it available. I'm not sure when they started adding it.
  14. darelldd
    6,057
    389
    Northern CA
    Quite possibly even more important - the Hindenberg wasn't filled with Nitrogen as far as I know.
    Hmmm, but maybe the fabric was coated with it! :scared:
  15. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    The Hindenburg was filled with Hydrogen.
    Maybe if you filled your tires with that it would give you a lighter ride.:p
  16. rep308
    rep308 Junior Member
    71
    suburbs of Boston
    I use a custom 80% Nitrogen 20% Oxygen blend (with a few trace elements thrown in to improve MPG). I'm building custom fill nozzles that go on a standard air pump and should have them for sale for $20 next week.
  17. Sufferin' Prius Envy
    3,998
    And the Return On Investment for those things should prove to make them worth their weight in gold for those who buy them from you - considering many gas stations are charging $0.25 to $1.00 to fill tires with that precious commodity. :rolleyes:
    And here to think I've been getting free nitrogen from Costco . . . and only needing to check my tires every few months. :boink:
  18. GatorJZ
    GatorJZ Member
    285
    17
    And you have the bonus of all that free moisture you are putting in your tires.
  19. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Mythbusters says helium didn't help footballs.... I say fill tires with NEON!!! Then they can glow from the inside out!!
  20. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    5000 miles and not even 1/2 lb low. Thats why I like N2. But I get it free also.
    fairy farts sounds interesting tho!
