What could be causing my Master Break Cylinder issue?
Discussion in 'Prius c Main Forum' started by thefyn, Aug 4, 2025 at 12:08 PM.
  1. thefyn
    thefyn Junior Member
    33
    Treasure Coast
    The warning lights just flashed up again re my master break cylinder not responding correctly on my 2012 Prius C 3
    I've replaced it with 2 previous used master cylinders in the past.
    I'm considering buying a new one instead of used but I'm worried the warning lights will come on again because of the possible issue being connected to the master cylinder.
    Is it just a coincidence that my 3rd one is failing or could the issue be something else? Like improper instalation etc? I do use cruise control a LOT.
  2. ChapmanF
    17,508
    51,273
    hard to say, but since prius actuators are prolematic, the odds might be against finding a good one.
    there again, if it is a source like ebay, there are a lot of bad actors out there these days
