What could this noise be from inverter pump 2009 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GoodByeGas, Jul 29, 2018.
  1. GoodByeGas
    GoodByeGas Junior Member
    17
    Bay Shore, NY
    What could this noise be on a 2009 Prius with 224,340 miles? Its coming from inverter pump. I see wave in reservoir, looks like coolant is circulating. Is it on its way out? How can i fix? Lol. Thanks.
  2. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    No, that is not the inverter coolant pump, that is the 3-way coolant control valve. You need to replace it.
    I haven’t done one myself, but I don’t think it is hard and the part is not overly expensive.
    All the best.
    GoodByeGas and Raytheeagle like this.
  3. GoodByeGas
    17
    Bay Shore, NY
    Been researching it and I believe you are right. Will definitely update on resolution. Appreciate it thanks.
