What dealer says re: batt and what I see do not jive
Discussion in 'Gen 2 Prius Technical Discussion' started by ieatsawdust, Aug 10, 2017.
  1. ieatsawdust
    ieatsawdust New Member
    Oregon
    My 2004 has 245k miles and has had few serious problems. Relied on dealer for good advice until now. Ck engine light in past always came back as gas cap issue. Bought a 2016 and the '04 was not driven as much. Then one day ck eng light became red triangle. Code reader showed P0A93 inverter coolant pump. Not wanting to do more damage, finally towed it in after 4 weeks. Live up 6 miles of Forest Service road 60 miles from the dealer. They call and say inverter pump bad, catalytic converter bad, HV battery bad. I say only one code was triggered and tell them to fix the pump. Pick it up and red triangle still there. Sheet says it was reset but then it came back and could not be reset. Warned me not to trust the car, like checking out of the hospital against medical advice. Drove home fine. Code reader still said P0A93. Disconnected 12v battery ground, red triangle gone, no codes. Dealer had said 8 of 14 modules were dead or dying and complete failure was imminent. Cannot resolve what he said and what I see. If it were that damaged wouldn't it throw a code? How bad does an HV battery have to be to show a code? Will a bad catalytic converter throw a code? Still can't reconcile three serious issues discovered by dealer and only one code showing and now no code showing. Any advice appreciated.
    49,458
    welcome!
    if any modules were actually 'dead', you wouldn't be driving it. however, if you want to test them yourself, to see how far out of parameters they are when under load, you need tech stream software.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    You should get codes for the HV battery and cat, if they had gone bad.
    To give the dealer the benefit of doubt, they would have hooked the car up to Techstream software and might have evaluated the entire car to put the inverter issues on context. Techstream will display voltages for each cell in the battery and the dealer might be basing their judgment on that rather than a code triggered. Can you press them for a better explanation of that and the cat issue, and maybe even get a printout of what they found?
  4. JC91006
    16,482
    8,398
    Wow all those problems, it's a death sentence
    edthefox5 likes this.
  5. ieatsawdust
    Oregon
    I'll check for more info from the dealer. You would think both the HV batt and converter would code. In this part of the world cars have broken down in desolate places and people died. No code could be deadly.
  6. JC91006
    16,482
    8,398
    The battery and catalytic converter will be $6000. And the little inverter pump another $500.
    Maybe they just want to sell you another new car?
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Letting an old HV battery sit is a death sentence. Codes/lights will be back.
    Beachbummm likes this.
  8. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    When you say not driven as much, on a Gen2 if it sits around the 12v battery discharges unless you turn off the smart key system under the steering wheel. It also does not charge up 12v very fast when you drive it, so you could be having trouble keeping the 12v adequately charged.
  9. bisco
    49,458
    it will code with a prius aware reader.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Buy a mini vci on amazon and do your own investigation. But odds are real good your hybrid battery is going south.
    You have a 13 year old car with quarter million miles on it.
  11. ieatsawdust
    Oregon
    We had just installed a new 12v batt just prior to this dance. Fotomoto, what time frame for not running the car would you consider a day too far?
  12. bisco
    49,458
    new is good, but always worth checking.
  13. JC91006
    16,482
    8,398
    If you can do much of the work yourself, then it wouldn't cost that much to fix
    1. inverter pump and coolant $120
    2. catalytic converter $100 + labor to weld on
    3. hv battery module swap and balance - $500 and that includes a charger from Hybrid Automotive
    Raytheeagle and edthefox5 like this.
  14. fotomoto
    5,602
    3,778
    So. Texas
    There's no hard rules but for my two failures it was a couple of weeks and just a few days of no driving. Lots of posts from folks saying they left their car for a while only to find trouble lights upon their return to drive it.
    Beachbummm and edthefox5 like this.
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Can be as few as 4-5 days. Usually within a week the stock style battery will be dead. A larger capacity battery sometimes gets to 2 weeks or so.
  16. ieatsawdust
    Oregon
    Time to pull the plug. She's been a treat over the years but we all reach the end of both the literal and proverbial road.
    Raytheeagle, Mendel Leisk and bisco like this.
  17. bisco
    49,458
    smart move, all the best!(y)
  18. Mendel Leisk
    38,713
    Here here: and this one's a bumpy/dusty forestry road. :)
    Raytheeagle likes this.
