What did I hit?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LDB, Oct 27, 2015.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Ok, so I didn't hit anything, the engine just started. Whenever it kicks in there's a klunk. It takes me by surprise sometimes and feel like I hit something. If I'm backing up it can be especially unnerving. How long does it take to get used to?
  2. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Yes, it does seem more startling in reverse, even after 13 months in my case. It's normal behaviour, though.
    #2 CR94, Oct 27, 2015
    49,478
    actually, i've nevr noticed that. did it just start, or was it there on your test drive?
  4. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    My 2009 Gen II does that occasionally, especially when the ICE is cold. I've always supposed it's just the same behaviour I've noticed with other (non-hybrids) when the engine is still cold (i.e. not too much to agonize over!) If you're really worried, you might try cleaning the sparking plugs! (Is the system throwing up any codes?) - hope this helps - Wil
    Edit: Engine mount? …er that's it! ;)
  5. bisco
    49,478
    maybe drive a new one to see if it does it.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Hard to evaluate just by the definition "klunk".
    But I'd say my Prius never or has very rarely "klunked" when the engine starts.
    I'd say if it's loud enough and shocking enough for you to routinely notice it? Then something is wrong.
  7. SwamppThingg
    SwamppThingg Active Member
    235
    443
    Mount Prospect, IL
    Even weirder I swear it happens to me in virtually the same place every time.
  8. LDB
    LDB Member
    279
    71
    It isn't extreme. It reminds me a bit of shifting the motorcycle from neutral to first gear. I think the biggest thing is that where one might notice it when starting a "normal" car, that's always dead still in park in the driveway. This is usually after a second or two while backing out, transitioning from EV to ICE while moving. Even though I've looked behind the car and am then watching in the mirrors and backup camera I still have that moment where I wonder if the aliens put something behind me to hit.
  9. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Yes my 2010 was occasionally clunky too. I chalked it up to a software hiccup and mistiming the spark or fuel injection during startup. My CMax doesn't do this.
  10. Mendel Leisk
    38,719
    I never notice anything, and I'm pretty cognisant to engine sounds. Maybe a loose engine mount?
  11. LDB
    LDB Member
    279
    71
    I guess that's possible. I don't really think anything is wrong. I think that's just how it is and like many other things it's just different in this car than any other car.
  12. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I don't know how anyone cannot notice the ICE starting up while backing up. When cold, my ICE generally starts right about when I get halfway out of the garage. It's never made me think I hit something though, but it's definitely not something I don't notice. I guess I should note that at that point the SiriusXM radio is just about to find it's signal and kick in, so the car is quiet when the ICE kicks in. Perhaps those whose radio is already on just don't notice the ICE kicking in as much?
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    You've already said it. We all notice it but have gotten used to it so that it is hardly noticeable. I have a PiP so I rarely hear the clunk as the ICE usually engages while I am in motion and I don't notice with the wind and road noise. However, when I run out of battery, yes, I do notice it.
    As to how long to get used to it? I don't know as I haven't gotten used to it yet. I was backing up the other day with no battery and the engine clunked to life startling me after 3 years and 83k miles of ownership. But like I said, I have a PiP so this was a rare occurrence.
