What difference does 1.6 miles and a "level playing field" make?
Discussion in 'Gen 2 Prius Fuel Economy' started by DaveinOlyWA, Aug 30, 2007.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well... my answer is about 4 mpg and let me tell you why...
    my commute used to be about 5.3 to 5.5 miles (one way streets makes the length slightly longer coming home) i lived two blocks from the southern most tip of Puget sound where Capitol Lake drained into the bay. it was a great view but on the side of a rather steep hill. total elevation changes was about 350 feet total going down, up and down again. i lived there over a year, and best mileage was 58.5 mpg...
    at beginning of the month, we started moving (paid rent at two places for august...fun) my new commute is relatively flat, 6.9 miles, total elevation changes based on my GPS is about 110 feet, no major grades, and now my commute is slightly faster ( all 35 or 40 mph verses half at 25, half at 35 for previous).
    just finished first full tank at new house, coupled with no major trips north, stats
    623.5 miles
    9.929 gals fill
    MFD mileage 62.7
    computed mileage 62.8
    ok. now that is probalby a fluke based on the fact that with moving, we did not have any major trips planned so that helped a bit, but other tanks with similiar situations were now better than 58 and my running average was only about 55-56 mpg anyway... my current tank with two trips to ikea (new furniture for house naturally which we hauled back in the Prius) is 58.4 mpg and will be getting gas today. it was over 60 mpg until the trips north....
    so, all in all, if you aint getting the good numbers, look at your commute, that is probably the culprit... it most certainly not your Prius
  2. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Yep. Anyone with the patience, will and most importantly the proper terrain can get +800 mile tanks with averages over 80 mpg.... like me! :D
  3. alexstarfire
    alexstarfire New Member
    220
    Man, your entire trip is all 40 MPH or less. Lucky fellow. Around here I'm lucky to see a sign that says less than 45 on it. Actually, I can't go more than 1-2 miles without hitting a road that does 40+ MPH. I could do better, but the driver riding my nice person the whole way would probably get really pissed.
    Anyways, 25 MPH is too slow to be that useful. It's great if you can do EV the whole way, but if the engine kicks on it's a bit under the sweet spot speed wise. 35 MPH is where I'd like to stay at, but hell even in 35 MPH zones all the cars go 40+ MPH.
    Glad you getting better mileage though.
  4. bwilson4web
    16,012
    <div class='quotetop'>QUOTE(Alexstarfire @ Oct 5 2007, 12:31 AM) [snapback]521600[/snapback]</div>
    Engine block heater.
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well now that winter is coming mileage is dropping like a rock... down to 55 mpg... need another solution...
    stay turned, a solution is coming and should be here in about 3 weeks...hehehe
