What do I do with my Prius while on vacation?
Discussion in 'Gen 2 Prius Main Forum' started by The Old Man, Jan 19, 2006.
  1. The Old Man
    The Old Man New Member
    32
    Los Angeles, California
    I've heard of the batteries going dead after leaving the Prius sitting for too long of a time. I'm planning a two week trip soon and was wondering what I should do to keep the battery from completely draining while I'm away.
    Is there a way to remove cables or something?
    Does anyone know? Or has anyone had this experience?
  2. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    Two weeks is just at the boundary where you might want to consider deactivating the SKS, if you have this option (by pushing the button right under the steering wheel). Other than that just make sure you don't leave any of the lights on, and you should be fine.
  3. arubinst
    arubinst Junior Member
    Lausanne
    I left my Prius for one month and 10 days. I deactivated the SKS and had no problem at all. The HV battery had as many bars as it had when I left. You'll be alright.
    Abraham
  4. Mystery Squid
    Mystery Squid Junior Member
    Just let mine sit for 3 weeks while I was down in FL. Came back, started right up like the day before I left it. You'll be all right.
  5. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    My friend is going to be disappointed. I told her she could use the car when I go to Italy in September!! Oh well, I 'll probably leave the keys anyway!
  6. The Old Man
    32
    Thanks for the advice and assurance. I was concerned about having to get a tow-truck to jump my Prius when getting back from my trip. I shut the SKS off this morning. Funny, though. I attempted to unlock the door and start the car without using the key fob several times today. Force of habit. It's amazing how reliant I've become to SKS. I damn almost pulled my shoulder trying to open the locked door! Ha ha!
  7. Brian K
    Brian K New Member
    152
    Hi T.O.M.,
    I own the "Prius on Vacation" service, and the good news is it's free.
    Just drop it off at my location in Maine and I'll drive it for you every day to keep things running A1. When you come off vacation, just pick it up here and you're on your way with a Prius that you know has been run to keep the systems "up".
    Hey, I'm all about helping people. Don't forget to fill it before dropping it off, OK?
  8. The Old Man
    32
    I'd have to take a vacation just to drive my Prius to your place in Maine (from California). ha, ha. Good try.
  9. Salsawonder
    1,897
    47
    La Mesa California
    I know lots of folks here in San Diego that would drive it for fun, maybe too much fun!! Sounds like SKS off is the way to go. Have a great trip!!
  10. Tideland Prius
    16,445
    And to minimise drain on the 12V, leave the headlight in the OFF position, ditto the vanity, dome and cargo lights.
  11. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Left mine in the garage for 3 weeks. It started right up...no problem. :)
  12. The Old Man
    32
    I'm back from my two week vacation in Central Mexico! I had a great time.
    Came home, unlocked my Prius, and found the battery charged at the level I left it two week prior. Thanks everyone for recommending that I shut off the SKS.
  13. kk6yb
    kk6yb Junior Member
    36
    2011 Prius Alpha
    The bars will always read the same after a shutdown since the HV battery computer has been off and doesn't know the battery has self discharged while it was shutdown. It takes about 15 minutes of driving for the computer to measure any SOC change that happened while it was shutdown (this was discovered by the Prius+ people who charged the HV batt while shutdown).
    In any case, the HV battery discharges very slowly. I left my 2005 parked during a trip recently and the HV battery voltage dropped from 224 volts (67.5% SOC) to 220 volts, losing only 4 volts in the 16 days it was left sitting (in 50-60F temps).
    The auxiliary 12v battery should be fine (unless it is defective) for a few weeks also. As others have said: turn off SKS and turn off headlights for maximum battery life while in storage.
    If you're going to leave a Prius for more than 2-3 weeks, I would try to make sure the HV battery is charged up to the point where you have green bars on the MFD. You can always get the 12v aux battery jumped but if the HV battery gets too low you won't be able to start the engine and won't be able to recharge it (except with a special charger the dealer will have to order).
  14. burritos
    burritos Senior Member
    4,946
    252
    What's SKS?
  15. Betelgeuse
    1,460
    24
    New York, NY, USA
    Smart Key System. It's the thing that's included on most packages (above the very base model) that allows you to keep the Key FOB (little remote thing) in your pocket, but still unlock/lock the doors and start the car. Sounds like just a minor convenience, but most everyone who has it thinks that they would never buy a car without it again. I agree.
