What do I need for servicing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by enginestarter, Sep 10, 2019.
  1. enginestarter
    enginestarter Junior Member
    66
    UK
    Active
    My Prius has 137,000 miles on the clock.
    I got with 130,000 miles.
    It was last serviced 1 year ago by the previous owner at a local garage.
    What do I need to do for servicing?
    I couldn't find a good guide on Youtube - I assumed there be many.
    A link to a recommended one would be great.
    EDIT: I see servicing kits on ebay. Good idea to buy? What should I buy? Different ones comes with different filters and oil.
    Thanks.
    #1 enginestarter, Sep 10, 2019
  2. Aegean
    Aegean Active Member
    428
    187
    Alexandria VA
    At 137k I would do the following maintenance if I was planning to keep the car for at least 3 years. Except if you have service records on some of these done recently.
    Brake fluid $15
    Coolant $30
    Inventer coolant $15
    Transmission WS fluid $50
    Air filter $15
    Cabin filter $15
    Belt $15
    Spark plugs $25
    Test 12v battery $0
    Check front brake pads $0-$40
    Clean throttle body $10
    Clean HV battery fan $0
    Oil and filter $30
    49,488
    log into toyotaowners.com and enter the VIN for past service info.
    you will also find a maintenance schedule there, if you didn't get one with the car.
    don't know anything about kits, but they sound like a bad idea
  4. enginestarter
    66
    UK
    Active
    Guys, since my post... I haven't yet serviced yet. :eek::eek:
    Just been busy.
    From the list @Aegean gave...
    What is 'Belt'?
    >> Test 12v battery
    I've seen a video on youtube - just go through the menu buttons?
    >> Clean throttle body
    This video shows:
    Is this the right one? Looks pretty simple.
    I just saw a video on this... seems quite a lot of work getting to!
    Is it absolutely necessary?
    ANYTHING else missed by list give by @Aegean?
    Thanks.
    @bisco - the car would have been privately serviced for the last few services, so I doubt there would be anything worth looking up.
  5. Mendel Leisk
    38,726
    I did a second gen maintenance schedule extrapolation, just taking the given patterns, extending them out, to 260K miles.
    enginestarter likes this.
  6. enginestarter
    66
    UK
    Active
    @Mendel Leisk That's really helpful.
    Given that I can't rely on what the past servicing has been, I guess it would be wiser to do everything possible!?
    I'm scratching my head now. Not sure what to do.
    What parts would you recommend getting for the service?
    Your docs suggest only: oil, oil filter and spark plugs?
    Let me know.
    Thanks.
  7. Mendel Leisk
    38,726
    @Aegean 's list is pretty complete. I would start with just an oil and filter change. Then a transaxle fluid change, since it could well be the original fluid in there. Second gen doesn't have a brake fluid change without Techstream documented: maybe talk to dealership about that, they could do for around around $100? Brake inspection should be done too. Visually look them over for starters. Depending on your comfort level, DIY or dealership. Inspect the engine and cabin air filters.
    I'm just scratching the surface. Take them one or two at a time, see how it goes.
