What do you consider to be overfilled oil?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by p626808, Jan 13, 2006.
  1. p626808
    p626808 New Member
    292
    I was taking my oil sample to be sent out for analysis (12,018.5 miles on the new mobil one enhanced 15K oil) When I looked at the dipstick for the first time..
    I did not see any "full" or "add" marks on the dipstick.. just 2 little bumps in the end of the stick.I presume that the normal operating range is in between these two bumps..
    My oil was towards the top of the two bumps...
    I took out about a 1/2 quart.. put a smigin back in.. and it seems my mileage improved a little bit this morning..
    Could that be? is MPG that sensitive to the amount of oil? Was my oil overfilled?
    Comments please..
    Scott
  2. richard schumacher
    7,664
    1,043
    United States
    Anything between the bumps is fine. Your change in MPG is a coincidence, caused by something other than the oil.
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    When it's running out of the PCV breather tube on the top of the engine. Quick story, about 3 months ago I had a job on a smaller Toyota forklift, it was hauled in to the shop at work and dumped on the steam pad out back, report was it wouldn't run and smoking. So I go out and start checking things out and notice a couple of things, there was oil on the outside of the engine and when I pulled the dipstick out oil ran out of the tube. OK slightly over full, go back and get my drain pan and drain 2 gallons of oil out of the pan. Check and I'd guess a couple of liters over the full mark so put the one sparkplug and on the 4Y engine the plugs fit in a tube that's sealed to the head with a rubber o-ring, fire it up and think well I'll just drive it into my stall and do some more checking. Well I'm half way to my stall (about 50 feet) and one of the other mechanics is yelling at me your leaking oil, look back and sure enough a trail, get it into my stall and open the cover and check the oil and its' running out the dipstick tube again. Now I know what the problem is so I drain out the oil till there's maybe 2 liters in the engine. Take the PCV breather hose off and get a piece of hose that fits and pull the PCV valve out and loop the hose from vent tube to the grommet for the valve, fire it up and head to the steam pad and when I get there open the hood and there is oil coming out around the spark plug tube where they go in the head. Shut it down and drain the oil till it's at the proper level and steam the oily mess off ( don't worry there is an oil recovery system on the pad drain ) pull the hydraulic oil pump off the engine and driver it back in my stall. Replace the pump and drain and change the oil filter and oil, refill to proper level and replace the plugs and air filter and return to the customer. The unit had about 18,000 hours on it. Still going after an over fill.
  4. p626808
    p626808 New Member
    292
    Interesting story...
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Good story Frank, I saw something similar on a D4 Cat we had on the farm where I grew up.
    I like to keep the oil just a bit below the top bump, but I agree anywhere between the two is OK. If it were more than a cm or so above the top bump I might take some out.
  6. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    My personal rule of thumb is that anything more than 1/16th above the full mark calls for siphoning some off (yes, with a straw).
  7. Oregon-Mica
    Oregon-Mica New Member
    36
    Southern Oregon
    This Forum is awesome! I checked my oil when I got home and it was a hair over the second bump. I was worried about this and so checked the forum. It was great to see this area so well discussed.
