What do you do with the old OEM mid body brace?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Former Member 68813, Mar 23, 2013.
  1. Former Member 68813
    3,524
    983
    US
    After you upgraded to a better one?
    I got a used improved OEM tubular one (thanks anewhouse!) to replace the old hourglass one.
    I wonder if the old hourglass one could be used to increase rigidity in front or back. I realize new holes may be necessary.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Same question I had. I was thinking that with a little grinding that two stock bars might be mounted. One up side down ( with the lip ground off) and the other in the normal position.
  3. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Lol. Mine is sitting in the garage, alongside the wheel covers. :D
  4. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    50
    Tampa, FL
    Ditto, but I also have a front plate bracket along with it all.
  5. Former Member 68813
    3,524
    983
    US
    LOL, I sold my wheel covers on ebay after I realized they damage the allow wheels. They sell very well.
  6. xpcman
    1,302
    295
    I am keeping them to re-install when I sell the cars. It will cover the curb-rash.
  7. Former Member 68813
    3,524
    983
    US
    OK, replaced the old one:
    with the new one:
    I really can't tell a difference during a short test drive. But the new one is clearly more rigid as I can't bend it in hands like the old one.
  8. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    How about donating it to a Gen II Prius owner?
    Same brace needed but the older cars didn't come with one installed by the factory.
  9. xpcman
    1,302
    295
    My 2008 came with a brace. I replaced that one also. I must have the old one sitting around somewhere.
  10. Mike500
    Mike500 Senior Member
    2,593
    766
    The Gen II brace is a whole 6 inches shorter and about an inch narrower.
  11. dhanson865
    851
    188
    TN, USA
    So it's only the Gen II OEM brace from a touring model that I could accept as a hand me down I guess.
  12. Mike500
    2,593
    766
    Both the hourglass and the tubular braces are designed to "twist." They are not that stiff when bent "end to end." The "ultimate"brace needs to "twist" but needs to ne very stiff when bent "end over end."
    That can only be accomplished with stiffer brace or intimately, a "box beam" like my latest design in the attached photo. It is like the one that Andy Newhouse and BreitrthrnU replaced theirs with. Their earlier versions function exactly the same way.
  13. Mike500
    2,593
    766
    That's correct. The Gen II brace is about 14 inches long and supplied with four M8 bolts. The Gen III braces is about 20 inches long and uses four M10 bolts.
    A lot of Gen II "stiffener" braces are not properly design to allow them to twist like the OEM brace and could exert extra stress on the mounting bolt area of the frame rails. Metal fatigue might NEVER show up or may many years down the road.
  14. Former Member 68813
    3,524
    983
    US
    Today I drive more in city on some rough asphalt and the ride felt more bumpy that I remembered on the same road. It' subjective though.
