What Does an "AC PreCharge Fault" Mean?
Discussion in 'Prius PHEV Plug-In Modifications' started by kilimar, Dec 19, 2016.
  1. kilimar
    kilimar Junior Member
    47
    So... I just spent 10-15 trying to figure out why my HyMotion pack stopped charging... saw that it was flashing/blink 7 times. Which is a "AC PreCharge Fault" -- but I can't figure out what that means from the manual.
    Does anyone know?
    Thanks,
    -d
  2. mrbigh
    3,686
    699
    Long Island, NY
    Pre charge is being used at initial AC or DC turn on to avoid a a sudden spike of electricity in to an electrical circuit,
    Usually is composed with a suitable relay and a charge resistor.
    Also is called " Soft start circuit".
  3. kilimar
    47
    So does that mean the relay and/or charge resistor is bad?
  4. mrbigh
    3,686
    699
    Long Island, NY
    It is related to the precharge circuit by itself.
    t could be an auxiliary electrical branch that powers a " timer circuit", a "driver circuit" or the power "soft start" initiating it's job.
    With out an schematic would be a little difficult to identify nor that the equipment error code will tell you much more.
    It is needed some body with the experience on this Hymotion's equipment to go further.
