What does "G.O.G." mean? (on my dealer maintenance receipt)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by davide, Aug 30, 2015.
  1. davide
    davide Junior Member
    86
    suburban Detroit
    I must have spent 10 minutes googling this strange term, without success. Apparently dealers of other makes use this term, too. The full phrase on my receipt says "G.O.G. & SUPPLIES". It looks like the "G.O.G." charge ($18.85) refers to the oil, and the "SUPPLIES" charge ($1.51) refers to the "SHOP SUPPLIES".
    (I recently went to the dealer for a filter/oil change, tire rotation, & recall-related replacement of the front passenger-airbag sensors in my 2012 Prius c. It's Sunday so I can't call the dealer for an explanation.)
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Grease, Oil, Gas
    MasterPri08 and Fishcrab like this.
  3. davide
    86
    suburban Detroit
    Jimbo,
    How did you know? I had never heard of this term. It seems to be a rare usage, but here it is on a Toyota dealer's official receipt.
    MasterPri08 likes this.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I googled it. My dealer tops up lots of fluids, brake fluid, windshield washer fluid, etc. and need a way to bill me for less than a whole container.
  5. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
  6. Tideland Prius
    16,155
    In Canada, it's just called "Shop Supplies" (which includes rags to clean their hands, washer fluids and other miscellaneous items. It's a flat rate per vehicle).
  7. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    If true, I hope they topped off the tank for you...
  8. Mendel Leisk
    38,728
    I was think along those lines. Really: they're gonna fill your tank? Regardless of how high or low it is??
    Typically there is nothing but washer fluid that could maybe use a top up, and we need to pay thru the nose for that? Better camouflage it with a very obscure and esoteric acronym.
  9. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Get Owner Good.
    xliderider, bisco and TC400 like this.
  10. Mendel Leisk
    38,728
    When our offspring go on vacation, I often get to take their vehicles under my wing. I'll detail the cr@p out of them, inside and out, and usually return them with the tank filled. But that's family!
  11. MasterPri08
    MasterPri08 Junior Member
    Minneapolis
  12. bisco
    49,500
    call the dealer and ask?
  13. Mendel Leisk
    38,728
    I like what @Grit said the other day (another thread), about a passive-aggressive, painstaking, item-by-item inspection of the invoice. Question each unintelligible entry; youre paying for them. ​
  14. bisco
    49,500
    strangely, when i take my car in, i tell them what i want. i don't let them tell me. so there's never anything on the invoice i don't understand.
    iow, if i want GOG, i'll ask for GOG, and i will know what i am paying for.
  15. Mendel Leisk
    38,728
    Your independent garage?
  16. bisco
    49,500
    generally, but i've been to a dealer or two over the last 50 years.
    if i want GOG, i'll dang well ask for it! don't try slipping any GOG in when i'm not looking, i'll make you remove it!:mad:
  17. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Make sure you have them explain in detail each service & what happens if you don't have the service done. Bonus points if you can get them to say that you will be a hazard on the road killing people or something along the lines of that. Then reply, No problem I'll just steer toward the sidewalks and road barriers so no one gets hurt.
