What does PCS (Pre-Collision System) do with the accelerator?
Discussion in 'Gen 4 Prius Main Forum' started by Colin Jones, Nov 15, 2016.
  1. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    OK - so we know that PCS will try to avoid a collision by automatically applying the brakes if you don't react, but does anyone know what it does with the accelerator? If you kept your foot on the accelerator when PCS kicks in the automatic braking, does it cut power to the engine at all, or does it just apply the brakes at the same time as keeping the acceleration going?
    Just a thought that occurred to me! (for example what if someone goes unconscious while driving) :)
    RCO likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Interesting question. Hopefully I won't try it. BUT - I remember the manual talks about something like pressing the accelerator abruptly as well as abrupt steering movements will disable the system.
    Not sure what would happen if the accelerator is already down hard. Have you checked the Manual?
  3. raspy
    raspy Senior Member
    438
    699
    London, UK
    From the manual;
    "The pre-crash braking function may not operate if certain operations are performed by the driver. If the accelerator pedal is being depressed strongly or the steering wheel is being turned, the system may determine that the driver is taking evasive action and possibly prevent the pre-crash braking function from operating.
    ●In some situations, while the pre-crash braking function is operating, operation of the function may be canceled if the accelerator pedal is depressed strongly or the steering wheel is turned and the system determines that the driver is taking evasive action."
    Oh, the manual also recommends turning off PCS before you drive the car in a sporty manner.
    RCO and alanclarkeau like this.
  4. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    Yeah - it still doesn't say what it would do if the accelerator is just being held in it's "normal" position though... i.e. does it cut the accelerator while braking (unless you then depress it hard), or continue running the engine at the same speed while braking. At a guess I'm assuming it will cut the accelerator to brake...
    alanclarkeau likes this.
  5. Tideland Prius
    16,615
    Perhaps the Drive-Start Control will take over? i.e. it'll reduce accelerator input while braking.
    Hence the "if may cancel if you depress the accelerator strongly". If you don't, it'll reduce power output.
    RCO and Colin Jones like this.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I would err on the side of caution and say it doesn't function. I would think that if you black out your foot would relax and come off the accelerator anyway, unless you have very heavy feet, the pedal has a return spring on it.
    RCO likes this.
  7. raspy
    raspy Senior Member
    438
    699
    London, UK
    I really need to find an empty car park, erect some cardboard cutouts and conduct an experiment. I really want to know what happens.
    Colin Jones and RCO like this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Just don't forget to put tin foil over the cut outs. It's said that it doesn't detect cardboard very well!
  9. Priifan
    Priifan Member
    93
    143
    Cary, NC
    Please add what happens when the car is on cruise control and another car suddenly pulls in front of it. It doesn't seem to matter much whether the distance ahead is set at 1, 2, or 3 bars. The car seems to slow down at different times even when there is no one ahead in my lane. And then does it try to tell me what speed would work under those conditions? Definitely tricky when you combine two or more features. Heeelllllpppppppp!
    RCO likes this.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Mine seems to only slow down if a car pulls in front then brakes or slows down quickly.
    RCO likes this.
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    The "throttle" is not a mechanical link but is computer controlled; fly by wire kind of.
    Put your vehicle in Park and press the "accelerator". Notice that nothing happens.
    I believe putting it in Drive with your foot firmly on the brake will also keep the engine from responding to accelerator input.
    It would be rather stupid of them to slow the vehicle (dramatically) without taking power off of the engine.
  12. alanclarkeau
    7,045
    7,593
    Check it out - in PARK, accelerator will still rev the engine - not to the extent of a traditional car, but definitely does.
    kithmo likes this.
  13. Sam Spade
    2,036
    1,023
    2017 Prius c
    Apparently all models are not designed the same.
    My C does NOTHING if you push the gas pedal in Park.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Nor my Gen 4 Business Edition (bit like a US 3) in neutral with P, accelerator would not bring on ICE.
  15. alanclarkeau
    7,045
    7,593
    I started it, left it in P(ARK), not neutral, pressed the accelerator and the ICE revved up - not much, probably only 12-1500rpm I'd guess, dropped back to idle when I released accelerator.
    kithmo likes this.
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Ok, my bad. I had park selected, so it would have taken me out of neutral, but the car was in ready mode.
