What does the "A/C auto switching operation" setting do?
Discussion in 'Prime Main Forum (2017-2022)' started by eegah, Dec 26, 2017.
  1. eegah
    eegah Member
    42
    27
    New Hampshire
    I'm confused about the "A/C auto switching operation" setting. As far as I can tell, it controls switching between outside and recirculated air. Is that correct?
    52,768
    is that in a set up menu?
  3. eegah
    eegah Member
    42
    27
    New Hampshire
    Yeah, it's in the settings on the navigation display.
  4. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Have you noticed you have something blue on the rear end of your car?
  5. eegah
    eegah Member
    42
    27
    New Hampshire
    What, you don't? Weird, everybody's got one but you. Don't you feel left out?
  6. Elektroingenieur
    2,515
    3,288
    Three Touring
    Toyota’s Repair Manual (available by subscription to techinfo.toyota.com), in the topic Vehicle Interior: Heating/Air Conditioning: Air Conditioning System: Customize Parameters, says that the Auto A/C Mode setting, under Climate Settings, controls the “Function to turn the A/C on automatically by pressing the AUTO button when the blower is on and the A/C is off.” The default setting is On, and it can be changed to Off, if desired.
    FuelMiser and eegah like this.
  7. bisco
    52,768
  8. Tideland Prius
    16,668
    As @Elektroingenieur says, it basically means that if you press the AUTO button and the A/C light is off, it will also turn the A/C on (along with the automatic operation).
  9. bisco
    52,768
    don't all pri do that?
  10. Tideland Prius
    16,668
    That was default to OFF in the Gen 3. (or at least the 2010-2011 ones)
