What does the Prius v engine sound like?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by sachi12, Sep 19, 2014.
  1. sachi12
    sachi12 New Member
    Hawaii
    I just test drove a 2012 Prius v today and heard a whiney noise, especially when braking. Sounded like a siren. 33,000 miles. Does the engine really sound like that?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    The hybrid system does. Its the sound of 2 large motor/generator units and a couple pretty large planetary gears. The "engine" as it were isn't running at all when you're braking below 45mph.
    If you're considering your 1st Prius, I recommend some reading up on the hybrid system.
    49,511
    and test drive a new one to know what they should sound like.
  4. Mendel Leisk
    38,739
    The hybrid system makes that distinctive whine any time you apply the brakes. I find it reassuring: charging, charging. ;)
  5. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    It's not the Noisemaker sound is it, to warn pedestrians ?
    It's not fitted over here in the UK, is it fitted in the US ?
  6. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Proximity Alert System. No, its not that. That sounds a little like a bad bearing, sort of a growl, and is only emitted under 15 MPH or so.
