What does the SET button under dash do?
Discussion in 'Gen 3 Prius Main Forum' started by hotbrass, Oct 15, 2009.
  1. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    What does the button under the drivers side of the dash marked "SET" do? I pushed it and nothing happened.:confused: Not that I was expecting anything. Just curious what it sets.
  2. jon_lin
    jon_lin New Member
    25
    Calgary
    Are you referring to the reset button for the Tire Pressure Monitoring System, much lower than the steering wheel?
    MITCHEROOO likes this.
  3. codybigdog123
    codybigdog123 Got Mad and Left in a Tizzy
    239
    29
    Chicago, Il
    There is a button under the dash, near the steering column which is used to reset/calibrate the tire pressure. More description of what it does can be found in your manual.
  4. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    This "RESET" button is important if you modify your tire pressures.
    For example, if you were to increase your tire pressures from, let's say 35psi front and 34psi rear, to 41psi front and 40psi rear, that would mean an increase in pressures of 6psi each tire.
    To the best of my memory, the TPMS warning light/symbol are triggered at a pressure of 7psi lower than that of the tires memorized pressure.
    If this were the case, at your current NEW tire pressures (each tire having been raised by 6psi), the next time you started your car, you'd get a Low Pressure warning, because the TPMS was set to alarm at 28psi front and 26psi rear, and your NEW values are now 13psi above your current set Low Pressure warning value, therefore, you'll get a WARNING!
    What the "SET" button does, is to teach the system a new alarm point whenever pressures are changed.
    Best I remember, set the NEW cold tire pressures, turn the car OFF, turn it back ON, Press the "SET" button and hold it for 3 seconds-I believe until the TPMS light begins to blink, let up the button and turn OFF the Power...your NEW tire pressure warning is now set (Initialized) to alarm at 34psi instead of 28psi.
    David (aka Blind guy)
    3 people like this.
  5. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    LOL, I'd be careful pushing buttons and THEN asking what they do
  6. Tideland Prius
    16,186
    Well David's got it all sorted out!
  7. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Thanks everyone.
    Great information and everyone is very helpful here!
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It lights up a message on the MFD that says "NEVER PUSH THE SET BUTTON!"
    Tom
  9. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    Thataway... just go about pressing buttons with no clue as to purpose. Watch out for that ejection seat button. If you don't know where that's located, check out your owner's manual.
  10. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Name a button that you can push with the Prius off that will do damage to the Prius?
    Now name a button that you can push with the Prius on that will do damage to the Prius?
  11. qbee42
    18,058
    3,074
    Northern Michigan
    There is only one button that falls into both categories: the SET button under the steering wheel. :D
    Tom
  12. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    From what David (aka Blind guy) said, you cant do anything by just pressing the button. There is other Voodoo, that you do, to make it work. Sorry Mel.
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    The button will start the count down beginning from 9. Just kidding. :D
  14. gbarry
    gbarry Junior Member
    79
    16
    S. California
    Found that button today...did a search...ended up here. Umm, what does that button do on my 2010 package II ? :p
  15. quantumslip
    quantumslip Member
    149
    Sugar Land, TX
    you gotta press it every 108 minutes, otherwise...
    Battery trouble. and J&TFalk like this.
  16. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I believe that won't be necessary after tonight. :D
  17. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Is that page missing from your owner's manual?
