What does the smog inspection actually do?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sorka, Jun 2, 2016.
  1. sorka
    sorka Active Member
    1,017
    197
    Merced, CA
    2019 Prius
    Has anyone watch their Prius get smogged? I'm assuming that they plug in a computer to the OBDII port and check the sensors and ECL and that's pretty much it.
    Do they do the gas cap check? Do they climb around underneath the car to look for CARB stamps and such?
  2. prius_power
    prius_power Junior Member
    57
    Ohio
    Used to live an a county where they do emissions checks, and will actually be moving back there. They do check to make sure there are no CEL, codes have not been cleared, and they also stick something up the tail pipe to make sure there are no excessive emissions, at least that is what they did 7 years ago.
  3. JC91006
    16,673
    8,518
    The emissions test in CA is just to check if there are any check engine lights on. They also are suppose to do a visual inspection as well.....but most are too lazy to do it.
  4. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Lightens your wallet about $50-$60.
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Having a Location in your profile would give us some hint which state's inspectors you were asking about.
    (and in fact aid us in almost any other question you may have)
  6. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    In CT. They check OBDII readiness monitors, physically identify a proper exhaust, cat efficiency and evap system monitors. They check your gas cap as well.
  7. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    In the Denver metro area we only have to do it once every four years (skip a two-year cycle) and all they do is check the OBD/systems ready and gas cap. They may sneak a mirror under there to check the CAT, but I haven't noticed. It costs about $25.
    tony2ltr likes this.
