What does this button under the power button do?
Discussion in 'Gen 3 Prius Technical Discussion' started by h1ph0panonymous, Mar 14, 2025.
  1. h1ph0panonymous
    258
    36
    No wording or anything near it but it does function (clicks in and clicks out out when pressed on once and twice).
    Prius 2014 Model (Trim/Style) 4
  2. ASRDogman
    ASRDogman Senior Member
    7,592
    3,916
    Pop it out and see if anything is connected to it.
    It could be some aftermarket switch someone installed...
  3. frodoz737
    frodoz737 Top Wrench
    4,699
    2,497
    33
    Not used on GEN III Level 1-4. Not sure, but believe it was used for Self Parking or something only available on Level 5...?
    h1ph0panonymous likes this.
  4. h1ph0panonymous
    258
    36
    I’m dumb, it doesn’t do anything when pressing for some reason I must’ve been confusing it for something else when looking around at the under steering wheel buttons in general. Was playing with the solar panel ventilate option button and must’ve forgotten to make a post asking about which battery it uses for that option (12v or hybrid battery pack) instead of this post. Sorry folks.
  5. h1ph0panonymous
    258
    36
    yeah sorry to waste time I was confusing it for something else I wanted to post about but remembered wrong when posting as just explained to another commenter in my response.
  6. ASRDogman
    7,592
    3,916
    Are you now saying it a blank cover? It doesn't do anything?
    "(clicks in and clicks out out when pressed on once and twice)"
    QUOTE="h1ph0panonymous, post: 3523064, member: 209482"]I’m dumb, it doesn’t do anything when pressing for some reason I must’ve been confusing it for something else when looking around at the under steering wheel buttons I general. Was playing with the solar panel ventilate option and must’ve forgotten to make a post asking about which batter it uses for that option (12v or hybrid battery pack). Sorry folks.[/QUOTE]
  7. h1ph0panonymous
    258
    36
    [/QUOTE]
    It’s a blank cover, was confusing it for another switch and my brain haywired when making this post lol but does the ventilate via solar panel switch use 12V or Hybrid Battery and is it worth using that ventilate while idle mode on sunny days?
    ASRDogman likes this.
  8. ASRDogman
    7,592
    3,916
    I don't know anything about the solor. My guess would be the 12v battery as the hybrid
    doesn't activate until the car is readied....
    It’s a blank cover, was confusing it for another switch and my brain haywired when making this post lol but does the ventilate via solar panel switch use 12V or Hybrid Battery and is it worth using that ventilate while idle mode on sunny days?[/QUOTE]
  9. AzusaPrius
    AzusaPrius Senior Member
    2,184
    920
    The solar fan uses the solar panel on the roof and that is all.
    I modified mine to charge my 12v battery though and it works perfect.
  10. h1ph0panonymous
    258
    36
    I feel like it would be better to modify it to charge devices while car is off and just chilling in the car if you can bare the summer heat with all windows open.
  11. AzusaPrius
    2,184
    920
    I also have it able to do that with the solar controller that has two usb ports.
    Then I ran extended usb cord to front, where I installed usb port with C port.
    I can turn it off/on with the Renogy solar controller APP and have power while the car is off. 20240529_134534.jpeg
  12. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    This is where the slot for the smart auto park button is.
    But your car doesn't have it, it's an empty slot covered with a lid.
  13. ASRDogman
    7,592
    3,916
    Just realized that the solar panels runs the fan.... Brain Fart!
