What Does This Label Under The Hood Mean?
Discussion in 'Gen 2 Prius Main Forum' started by Sid, Oct 16, 2005.
  1. Sid
    Sid New Member
    284
    Pennsylvania
    None of the performance warranty tests of 40 CFR, part 85, subpart W, is to be performed.
    This label is affixed to the underside of the hood, on the left side. What is it referring to?
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    82
    Obviously 40 CFR, part 85, subpart W. :huh:
  3. Sid
    Sid New Member
    284
    Pennsylvania
    My apologies for not being more precise in my question, so let me rephrase the question: What does that label mean? :)
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    probably has to do with the car not running at idle and as such would fail the test. If you google it there is pages but reading it leaves me to believe that the car would fail the test because it had failed the idle portion of the test.
  5. Sid
    Sid New Member
    284
    Pennsylvania
    Thanks!
  6. davidstdy
    davidstdy Guest
    :blink: It has something do do with the EPA....compliance with refrigerant I think.....but don't qoute me on the refrigerant part, I don't think I even spelled it right!
  7. Bill Merchant
    4,096
    82
    I think Frank's right, Sid. I was just tweaking you... sorry. :mellow:
  8. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
  9. Bill Merchant
    4,096
    82
    Of course! That's why the label is confusing. If only Toyota had referred to 40 CFR §85.2201 et seq Sid wouldn't have asked his question!
  10. Sid
    Sid New Member
    284
    Pennsylvania
    No problem, your first answer was funny. :D
  11. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    LOL as long as were tweaking each other....If the label bothers you, just peel it off. LOL
  12. jeromep
    jeromep Member
    827
    Eastern Washington State
    Simply put, it means that this car doesn't do well in your plain vanilla emissions test because fully warmed up and at rest it will not actually be running.
  13. Frank Hudon
    4,147
    also part of this test is in neutral and 2500 RPM which puts MG1 very near it's designed maximum speed. Above in the Classic and almost right at the maximum speed in the G2 Prius. If I floor the Classic in Neutral or Park about the max RPM I can get is 1850 RPM, which puts MG1 at about 6000 RPM.
  14. mrv
    mrv Member
    120
    ME, USA
    2018 Prius Prime
  15. Mystery Squid
    Mystery Squid Junior Member
    I would like to start a Bill Merchant cult.
    Who's in?
    :ph34r:
  16. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Count me out.
  17. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Do I get to wear one of those HSD labels on my forehead?! :rolleyes:
  18. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Watch out, if you do that, you may start posting using oversized fonts.
  19. Spartan
    Spartan New Member
    62
    North West N.J. USA
    :lol:
  20. Mystery Squid
    Wow, you all DO have a sense of humor! :lol:
