What every new PIP owner needs for Chistmas
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 3PriusMike, Dec 20, 2012.
  1. 3PriusMike
    3,092
    2,413
    Silicon Valley
    MeterPlug | Measure the electricity your appliances us at home
    This Bluetooth controlled power plug measures power and allows remote on/off via smart phone app. Seems like it would be easy to make it into a timer, charge for X watt-hours, etc.
    Simple and small...seems like every EVSE should come with this built-in.
    The only real limitation is that you must be within Bluetooth range.
    :-( not yet for sale...need to wait a few months
    Mike
    mrbigh likes this.
  2. mrbigh
    3,686
    699
    Long Island, NY
    Like it !!
    Pre-ordered mine (2), it's only matter of some time....
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I would have to get a new phone, my current phone is not Android 4.0 version.:cry: :notworthy: :sick: :sleep: :( :mad:
    Tami Topper likes this.
  5. ny_rob
    1,968
    813
    L.I.- NY
    Here's what I got my PIP for Xmas (from Amazon) for $22, I like my pizza hot!
    Hi Burrito! likes this.
  6. innerpri
    innerpri Junior Member
    55
    MD
    Thats a good idea, I am tired of my jacket smelling like pizza for a few days after I zip the pizza boxes in it. I like meter plug idea, should be on a regular outlet...monitor the whole house one day!
  7. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    So this device gives the same info as Kill-A-Watt, but over your cellphone instead of a readout on the device, when you are within Bluetooth range. If there is an advantage, I'm afraid I don't see it. Plus the Kill-A-Watt may be cheaper, depending on the model selected. Now, if they could make it so it fed info to your cellphone while you were away from home.........
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    it has data logging capabilities that kill a watt doesn't
    rogerv likes this.
  9. rogerv
    1,639
    317
    OK, thanks.
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    it also has a memory so you can download the data when your phone is hooked to it later on
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    they don't tell us what the app will cost tho
  12. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
  13. 3PriusMike
    3,092
    2,413
    Silicon Valley
    It is software controlled from the phone.
    You can do remote on/off.
    You can do unattended remote on/off/logging (in theory, just more software)
    Mike
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    plus, you can compare ac-curacies between Kill A Watt and Meter Plug:D
    lensovet likes this.
  15. mrbigh
    3,686
    699
    Long Island, NY
    As an average iPhone app may be $2.00 bucks but should be for free with an access code for the plug purchasers.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    kool:cool:
  17. priusenvious1
    priusenvious1 Member
    325
    37
    LA
    The advanced models have the entunes app that allows for charge monitoring. I don't know why you'd want to stop charge remotely.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    some ppl don't have the luxury of the advanced model:p
  19. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    What a great idea this little device is. I could easily take my 10' tablet that has bluetooth, put these around the house and monitor it all! I could also add a Bluetooth card to the Solar Monitor Computer.... Potential!
    Sweet!
    I ordered 2 to check them out, but if they function like stated, I will probably get many more
  20. 3PriusMike
    3,092
    2,413
    Silicon Valley
    Because you started charging to go out later and you changed your mind...you want to try and have a full battery right when you leave.
    Mike
