What goes into the molded plastic above the aux.battery?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PixelRogue, Jul 13, 2015.
  1. PixelRogue
    315
    57
    US
    Appears there are molded spaces in the plastic above the auxiliary battery compartment on the 2012 pip. Anyone know what these were designed to hold?
  2. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    The black fabric is used to hold one end of the tonneau cover for stowage. The other end is underneath the cover on the left hand side.
    Don't know what the other depressions are for (don't have a PIP.)
    #2 RRxing, Jul 13, 2015
    48,987
    mine are empty too. this may have been answered before, i can't remember. it might be in the manual, but that's 700 pages of searching. the other end has the air compressor. maybe the advanced has a first aid kit or something?
  4. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    Mine came empty, but I put a couple bungie cords in there.
  5. el Crucero
    el Crucero Senior Member
    1,628
    698
    Inland Empire
    I have a 2012 PIP with AT option. The black velcro "cups" on right and left are for the tonneau cover stowage. The left side holds the tire compressor. The right side is empty for whatever you want to put there.
  6. El Dobro
    El Dobro A Member
    6,972
    3,209
    There was an old thread on this and it wasn't answered back then either.
  7. srl99
    srl99 Member
    113
    23
    2014 Prius Plug-in
    I thought it was for tire hold down strap - which you are highly unlikely to use unless you have a spare.
  8. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    I have exactly the same in a UK PiP.
    Obviously a right handed widget fits in exactly.
    I keep a spare mobile phone and charging cable in mine though, as most widgets are imperial in size and here I can only find metric sized ones.
    Trollbait and bisco like this.
  9. Trollbait
    11,327
    A cubby on the cargo area side will is used for a optional first aid kit available in Europe. Someone came up with a way of installing bungee straps to make it useful elsewhere.
    So these are likely market specific. If Prius PHV only, I'd say they are for cables or other components to the emergency generator option in Japan.
  10. PixelRogue
    315
    57
    US
    thx - good to know nothing was "missing"
