What grade of gas is best?
Discussion in 'Gen 3 Prius Fuel Economy' started by passion222, Sep 30, 2012.
  1. passion222
    passion222 Junior Member
    23
    Shelton, Ct
    I was told 87 is what should be Put in Nothing more. Is this true?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Yes, although above 4500 feet 85 Octane is OK
  3. Former Member 68813
    3,524
    981
    US
    Higher octane is not going to kill the car, but not necessary. I would pay attention to brand of gas instead. Top-tier vs no-brand ones.
  4. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    There is no reason to use higher octane, but higher octane will do no harm except wasting some money. No need to be concerned if someone does put in higher octane.
  5. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Not true at all, especially if your Prius is a gen III(2010 or newer).
    The Prius Atkinson cycle engine will not be harmed by the minumum 87 octane fuel, but may not make it's best fuel economy as the operators manual says, use 87 octane OR HIGHER..
    A high compression engine can benifit from higher octane fuel, to produce more power and better fuel economy. The Prius engine uses variable cam timing to adjust cylinder pressure as high as the fuel octane will allow without detonation, to produce the highest cylinder pressure and the best conversion of fuel to power / economy.
    If you notice in the engine specifications, the Prius 1.8 engine has a mechanical compression ratio of 13/1 ,although the Prius engine uses variable cam timing to effectivly reduce cylinder pressure to that of a somewhat lower compression engine.
    The Prius engine can lower it's effective compression ratio to as low as 9-10/1 at low rpm wide / open throttle to prevent detonatiopn, yet adjust it to as much as 13/ 1 at light throttle / high rpm, to get the most fuel efficiency at any throttle opening and fuel octane.
    I have driven my 2010 Prius now for 3 years / 30,000 miles, and consistantly find a couple more mpg when using my local stations 89 octane E10 vs their 87 octane regular.
    This is with their 10% ethanol blend which in theory should have 3% less energy than 87 octane straight gasoline, yet my fuel economy is better. I suspect better fuel conversion of the higher octane fuel has to be the reason, as both the E0 and E10 use the same gasoline base stock through the companys blender pumps..
    An added benifit, I use 10% less imported oil and it is priced 5 cents per gallon cheaper :)
  6. fuzzy1
    10,150
    Not true. The 2010 Prius info sheet very clearly labels that 13:1 ratio as an expansion ratio, not a compression ratio. Too bad the 2012 info muddies the waters by calling it a compression ratio.
    From the details on the valve adjustment range provided elsewhere, one can compute the real compression ratio. I seem to remember a maximum compression ratio in the range of 8.5-9 to 1, and a minimum around 4:1.
  7. Jon Hagen
    336
    136
    North Dakota
    Would you post a link to that info sheet ? All the 2010 advertising booklets and operators manual state the the engine has a 13/1 compression ratio. Also, unless the minimum intake valve timing closes the intake valve well (30 degrees +) after BDC on the compression stroke, 13/1 is very possible. 8.5-9/1 might be reasonable with low octane fuel at low rpm and wide open throttle, but sounds rediculous for light throttle cruise. I can't imagine any conditions where 4/1 is appropriate ? Don't confuse EFFECTIVE compression ratio, which is controlled by the variable intake valve timing, with the mechanical compression ratio which is the volume of the cylinder at BDC compared to the volume of the combustion chamber at TDC.
    A quick search of Toyota and several other sites confirm that the engine has a 13/1 compression ratio, although the Atkinson cycle valve timing puts it at an EFECTIVE 9.5/1 under certain high load conditions.
  8. fuzzy1
    10,150
    This is from '2010_Prius_Product_Info_FINAL.pdf', which I retrieved March 9 2009 from pressroom.toyota.com in response to a PC posting. It is no longer there, but Google points to an archived copy at priustouringclub.com, though in a form that I cannot directly link.
  9. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    I appreciate this discussion, as I have operated (blindly?) upon the assumption my 2010 would respond similarly to my 2007. In the Gen II, I would get noticeably lower MPGs with higher octane fuel. I do know with the 2010 that ethanol-free regular has led to higher MPGs, but it is quite difficult to find in the Midwest.
  10. fuzzy1
    10,150
    According to http://techno-fandom.org/~hobbit/cars/valvetmg.png, intake valve closing varies from 72 degrees after BDC at the earliest, to 105 degrees at the latest.
    If I'm doing the math right, 72 degrees limits the compression to 68% of the cylinder volume, or 8.85 compression ratio. 105 degrees corresponds to 42% of cylinder volume, or 5.4 ratio. Am I missing something here?
  11. Jon Hagen
    336
    136
    North Dakota
    Possibly not, what I was missing is that the engine must meet emissions specs. They may be keeping cylinder pressure low to avoid nitrous oxide formation at high combustion temperature. That conservative cylinder pressure makes no sense from a pereformance / economy standpoint, but may be necessary for emissions reasons. Thanks for posting the valve timing link.
    If emissions could be ignored, the already extrodinary Prius mpg cold be even better.
    My 2010 Prius does better mpg(avg 2) with 89 octane E10 VS 87 octane E0 base stock from the same supply tanks at the local blender pump.
    Other E10 fuel is hard to compare because the base gasoline stock can vary so much in quality and BTU content.
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    If you are going to use "effective" compression ratio, then you should use it for all cars. The average car is at about 7 to 7.5 when valve timing is considered.
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  14. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    So If I fillup with 85 Octane in the Colorado Mt's. and use that
    same 85 Octane gas at sea level would the engine still run
    as if on 87 Octane???
  15. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No. 85 Octane is for above 4500 feet.
  16. WE0H
    WE0H Senior Member
    3,247
    527
    E30 works well too ;)
    Mike
  17. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    However, Toyota specifically warns you not to go over E10, repeatedly.
  18. WE0H
    WE0H Senior Member
    3,247
    527
    Yea I seen that. Wonder if the tank will melt or something strange? I do know Prius likes that E stuff. Oh well :)
    Mike
  19. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    But the fuel system seals don't take kindly to E30. as mentioned above, stick with a max. of E10.
    DBCassidy
    kgall likes this.
  20. WE0H
    WE0H Senior Member
    3,247
    527
    Oh for sure run E10 or straight dino-gas. Wonder how long the Prius will go until those seals give it up?
    Mike
