What happens when you run a Prius out of fuel?
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by Paul Gregory, Oct 24, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    I ran my Gen 3 out of fuel years ago, and I was surprised when the engine finally died at 181 kms, after the red indicator came on. The car would still limp along at about 30 kph. I have no idea how far this would have got me.
    My Gen 5 behaves as follows:
    The red refuel indicator comes on with 40 kms remaining on the fuel range indicator. A message, "Refuel" shows on the console about every 10 minutes.
    When the fuel range indicator reaches zero, the range is replaced with the word, "Refuel." The console message no longer appears. At this point, I set the trip meter to see how far I got before the engine quit. The car does not switch to EV mode when this happens; it just runs on the battery, which had more than enough charge to get me home.
    The engine finally died at 99.8 kms. This is the message:
    Overall range after first "Refuel" warning, ~140 kms.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,331
    519
    New York State
    2026 Prius
    Good to know. An advantage of the PHEV vs HEV.
  3. Paul Gregory
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    I was at the end of a long road trip, and I had fully expected to run out of fuel along the way, based on the distance to home and the indicated fuel range. I recall seeing "233 kms to home on Google Maps, and 103 kms fuel remaining." I had kept more than 40 kms EV range as a reserve.
    As it happened, when I got home, I still had fuel, so I took an extra excursion to see when I ran out of fuel. which turned out to be about another 30 kms. Quite a surprise.
    VelvetFoot likes this.
    52,538
    how did you refuel? when i ran out in my 08, i had to get a gas can with a skinny nozzle to fit through the check valve
  5. Paul Gregory
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    I didn't have to refuel this time.
    I had over 40 kms of EV charge.
    I used to carry a plastic fuel can, but it always leaked a little, and smelled up the interior.
    I ordered a metal fuel can, and it doesn't leak any vapors if the lid is kept tight. I know that some cops frown on carrying a fuel can in the car, so I keep it in the cardboard box it came in.
    #5 Paul Gregory, Oct 24, 2025
  6. Paul Gregory
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    As you may know, I ran my fuel tank bone dry doing a total range test.
    I filled the tank today, and the amount was 40.022 L, or 10.5 US gal. or 8.8 Imperial gal.
    #6 Paul Gregory, Oct 24, 2025
  7. AgentPTFC
    AgentPTFC Member
    59
    40
    PNW
    2025 Prius Plug-in
    XSE Premium
    So just like in EV mode when it runs out battery it just seamlessly switches to gas. And in HV mode when it runs out of gas it seamlessly switches to battery. That's good info! I had wondered if running out of gas would prevent it from using the battery for some reason.
  8. Paul Gregory
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    I never quite understood the difference between HV mode and HV/EV mode; it seems to switch between them on its own. Anyway, when I ran the fuel tank dry, it was in HV/EV mode, and the energy flow diagram only showed power flowing from battery.
  9. Tideland Prius
    16,631
    Thanks for running the test! This is good information.
    I guess it just ran on the remaining battery charge (as you said, it didn't go into EV mode, just ran on the battery). I can't remember if previous Prii did that or not. But either way, a regular Prius has a much smaller battery than the PHEV.
    otatrant likes this.
  10. Paul Gregory
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    I have a gas can in the car, but I didn't need it. I was able to make it home easily in EV mode.
    I ordered a metal fuel can online, because the plastic ones always leaked vapors in the car.
    I hadn't realized that fuel cans with crimped seams will always leak a bit, and it still made my car smell like gasoline. The solution was to dissolve a tube of Seal-All in a cup of acetone, pour it in the can, and leave it outside until it evaporates. It's been over a year, and still no leaks.
  11. bisco
    52,538
    that's the benefit of testing, over a senior moment
    PrimeDan likes this.
