What is amp hours rating of the Prius C 2014 traction battery?
Discussion in 'Prius c Technical Discussion' started by Arwen, Oct 11, 2015.
  1. Arwen
    Arwen New Member
    Denver
    2014 Prius c
    I understand that the traction battery is 144 volts and rated for up to 19.3 kWatts, but what is the capacity in amp hours? I can not find the any information other than the instantaneous power rating, but I want to know the capacity.
    49,693
    welcome! it might be in the tech manual.
  3. Arwen
    Arwen New Member
    Denver
    2014 Prius c
    No luck. There is nothing in the manual except the voltage, not power or energy. Was wanting to know Amp hours or at least what type and how many batteries make up the battery bank so I can figure it out myself.
    49,693
    if you scour the battery rebuild threads, i'm pretty sure the cell type and quantity are covered.
  5. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    Per Toyota, the capacity for the 2015 Prius C is 6.5 ampere hour. I wouldn't think the 2014 is much different than the 2015
    ftl and bisco like this.
  6. Arwen
    Arwen New Member
    Denver
    2014 Prius c
    Thanks!!! That is exactly what I needed.
