What is double the EV range worth?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jerry Liebler, Jan 19, 2014.
  1. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    I'm a newbie PIP owner ( see "My Recycled PIP" post in the newbie area) who got a PIP but really wanted a longer EV range. I chose the PIP rather than a gen 2 with one of the plug in mods to get the benefit of the advances made in the gen 3 and PIP, even though with the modified gen 2 I could get the range I wanted which would cover, in pure EV mode, my frequent trips to town which are between 18 and 25 miles. There is a range extender kit, for the PIP, from a company called "Plug in Supply" but it severely reduces the already limited luggage volume. At $ 6,000+ I'll stick with the stock set up! However at say $2000 for an extra 2.6 kw useable that fit below the 'trunk' floor I'd likely go for it.
    Would you?
  2. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I know that I would, but my housemate, the car's primary driver, wouldn't. We're sort of lucky, in that the car has more than enough EV range for the weekly trips into town, and not nearly enough for the commute, freeing us from trying to stretch out those meager electrons...
  3. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    As long as it didn't also decrease ICE mpg. A lot of us got the PiP because we have short range commutes within the PiPs limited EV range. Then we may have multiple long trips per year that make it a vehicle that uses less gas for our driving patterns than the Volt and some other PHEVs with longer EV range.
    Keeping our fingers crossed for the next gen PiP, but 25-50% more EV range seems to be about the best educated guess around here.
    CaliforniaBear likes this.
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Any information on options to increase the current PIP range would be interesting. While I'm currently at 76% EV after one year and 6000 miles, any additional increase in EV range would be welcomed. With the Gen 4 Prius around the corner, probably best to see what happens there. I'd like to see a minimum, solid 35-50 mile EV range. Please don't offer the Volt (javohl) as a option. I can wait for the next Prius.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'd settle for at least 50% extra range, but also think there should be a lower spec and thus cheaper version. The PIP here is fully fully loaded and priced accordingly. Probably why only a handful are sold.
  6. bisco
    51,154
    sign me up!:p
    retired4999 likes this.
  7. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    If I have power steering, electric windows and a/c, I'm happy.
    Don't need any of this fancy nonsense in the top end cars :confused:
  8. bisco
    51,154
    agreed, that's why i have the base. to each his own, a la carte options would be nice!
  9. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    But we don't have a base PIP here, just the fully loaded super duper one.
  10. bisco
    51,154
    understood. we have things you want, you have things we want. frustrating.:mad:
  11. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Since a major priority of the design was to keep PHV competitive with the true competition... tradition vehicles ...it's not realistic to expect a major increase in battery-pack capacity. Too much would easily push the cost out of reach for mainstream consumers. That would sacrifice both cargo-space and depleted-efficiency too. Toyota could offer an additional model with higher specifications, but that's clearly not what the masses have been asking for.
    I drive close to 20,000 miles per year. Being able to recharge at work is nice. It doesn't cover my entire day though, not even close. I also take frequent trips well out of that doubled capacity's range. There isn't even a pattern. Each day is different... as these graphs of my daily driving clearly show:
    Fortunately, the demands of real-world are well suited for the Prius design. Lifetime MPG is above 75. That makes the benefits of the plug, despite lots of miles per year, very easy to see. Toyota delivered a system available as an affordable choice without having to give up the aspects of Prius which made it a popular.
    The next generation will build upon that. We'll see improved engine efficiency and refinements to EV mode. A modest capacity increase is realistic too. But don't forget about the importance of keeping it competitive with the true competition.
  12. bisco
    51,154
    agreed, i'd be happy with a 33% increase in capacity, 10% increase in mpg's, return of the jedi, er, i mean spare tyre and a total redo of the interior logistics.;) is that asking too much?:p
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    My one year of ownership got me 40% EV with 100 MPG gas consumption.
    Fuel economy breakdown showed I got 56 MPG on gas miled and 132 MPGe on electric miles.
    Refining on this with a bit more EV mile would be nice. They really need to put electric defogger. Heated electric seats are fine.
  14. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    I was very satisfied with the PiP-A's EV range until my son and I went halfies on the Ford Fusion Energi with its reliable 23 - 25 mile EV range. Grrrrr..... I realize it's purely psychological.
  15. brewcrew9
    brewcrew9 Member
    111
    Madison, WI
    2014 Prius Plug-in
    I always thought that the factory OEM module battery system
    Would be perfect. Meaning, sell the car as is currently but also
    Have a system in place that allows users to add a certain amount of batteries
    From Toyota. That way up they can keep the cost down AND allow certain users the ability
    To add ev mileage as needed. I hope someday there is a OEM system for this.......
    DadofHedgehog likes this.
  16. john1701a
    12,797
    5,280
    57
    It's difficult to determine what the market is that's willing to give up significant storage capacity. Look at C-Max for a great example of the tradeoff required.
  17. bisco
    51,154
    cmax is just bad design for a plug in. best move on the gen four would be to design for the plug to have same space as current liftback and give the extra space to the new liftback. unless they can't pull it off and keep the mpg's up. no doubt we are expecting a lot, but they are very good engineer's.
  18. bisco
    51,154
    and heated steering wheel!(y)
    usbseawolf2000 likes this.
  19. retired4999
    2,652
    625
    Eau Claire, Wi.
    (y) :D
  20. bisco
    51,154
    another change i'd like to see (which shouldn't cost much) would be a vent position for defrost only, instead of defrost/feet. then i wouldn't have to stuff foam in the foot outlets every year.:cool:
