What is license plate screw size
Discussion in 'Gen 2 Prius Main Forum' started by stevecaz, Jun 16, 2008.
  1. stevecaz
    stevecaz New Member
    77
    Massachusetts
    (nothing in search)
    OK, quick and odd question - what is the license plate bolt size?
    I pick up my Prius this week, and I'm transferring plates that I'm bringing to dealer. I attach plates to my cars using stainless steel hex head bolts and want to bring these with me. Most cars seem to be M5 or M6, and only a short couple cm length is needed.
    Thanks
  2. fcc
    fcc New Member
    245
    Nashua NH
    i cannot answer your question but did the front plate kit only come with two screws
    in your car?
    i know mine only came with two when in reality you need four to make things work.
    i simply asked the dealer for two more when i visited after buying the car and had
    the plates in hand.
    sorry to interrupt your thread but i am guessing you did not get them either!?!
  3. autoxic
    autoxic Commuter
    111
    Richmond, VA
    I happen to have a Toyota license plate screw here on my desk at work, which I took from a dealership last week, for some odd reason.
    The threaded part is 5/8" long exactly. The outside diameter of the threaded part is 7/32". The head of the screw is 6/32" tall. Maybe you can test out some bolts on a friend's Toyota.
  4. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    The thread diameter is 6mm. The required length varies depending on your frame.
    EDIT: Note - I believe most foreign cars use a 6 mm diameter thread, while most American cars use a 1/4 inch diameter thread.
  5. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    It is a fine thread bolt.
    hehe, I had to check.
    ZC1
  6. stevecaz
    stevecaz New Member
    77
    Massachusetts
    Perfect, thanks.
    So it appears to be M6-1x20mm.
  7. Yankees251
    Yankees251 Black Touring HI Package
    96
    Danbury, CT
    Why are there only two holes in hatchback for screws? I would love to use 4 screws, any way to do this myself safely?
  8. Boo
    5,051
    483
    97
    Flushing, NY
    For both the front and rear license plates, the license plate attaches via the two top screw holes.
    I use four screws. For both the front and rear license plate bottom two screw holes, I use a shortened plastic screw and nut. In addition, for the rear I use a pad so the screw and nut do not scratch or dent the metal.
  9. Yankees251
    96
    Danbury, CT
    So your bottom two screws are just for show?
  10. Boo
    5,051
    483
    97
    Flushing, NY
