what is maint recq?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aspens3, Oct 8, 2012.
  1. aspens3
    aspens3 Junior Member
    25
    Alaska
    What does the message on the dash mean "maint recq"?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The light comes on every 5000 miles from last reset. It's to remind to your perform required maintenance, which is at minimum, an oil change.
    You should reset the 5K mile count once the oil change is performed, if the place doesn't do it for you. Toyota dealers know how to do it (it's in the manual and requires no special tools) and have always done it for me when I go there for an oil change. Others might not and you might have to do it yourself.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,917
    4,678
    Texas Hill Country
    Unless you had a newer Prius, then the 5k reminder could mean only Rotate Tires since oil changes are at 10k intervals using synthetic oil.
  4. aspens3
    25
    Alaska
    Thank you. I applied the remedy and rectified the problem.
