What Is "Normal" and What Is "Rapid" Fluctuation in Batt Levels?
Discussion in 'Newbie Forum' started by BartonGDawes, Sep 7, 2016.
  1. BartonGDawes
    BartonGDawes New Member
    Colorado
    I understand that rapid fluctuation in battery charge levels is a sign of a weak hybrid battery, or at least a potential sign that it might give. As I am a new Prius owner (meaning, I've only owned a Prius for three weeks, but the Prius itself is not new---it's a 2009 w/ 80K miles), I don't know what is "rapid" or what is normal.
    So, would it be normal if I park the car in my garage and the battery level is one bar above the mid-point, and then after starting it 24 hours later and driving it for 10 - 15 minutes on flat or uphill surfaces, that the battery level dips to two bars below the mid-level, but then will also charge back up to one or two bars above mid-level 10-15 minutes later?
    For example:
    -Start the car for first time in 24 hours. Battery is at one bar above mid-point.
    -Drive for five minutes, accelerating, etc. Battery falls one bar. Drive some more, take a few hills, battery falls another bar.
    -Stop, turn off car, do an errand.
    -Get back into car, and drive for another three or four minutes. Between braking and some downhills, battery goes up a bar.
    -Drive a few more minutes, same thing.
    -Home, with battery either at exact same level I left it at, OR one bar above (sometimes below).
    Our battery rarely goes into the purple-colored low zone, and when it does, it charges right back to the midpoint in a matter of 10 minutes, no problem. But for the most part it stays between two bars above mid-level and two bars below mid-level, but it will definitely fluctuate within that range (in both directions) in a matter of minutes.
    I have also simplified it somewhat in suggesting that the battery only falls in the first part of the journey, but only charges in the second. In reality, it will go up and down in both directions. However, I have noticed that after 24 hours, the battery will discharge more rapidly after first starting the car and driving it, and then it will charge more rapidly after the car's been "warmed up" with 10 - 15 minutes of driving.
    Is this considered fairly normal fluctuation? Or is this a sign of rapid fluctuation?
    I just got confirmation that our warranty was successfully transferred. It lasts until September of next year or 100K miles. (We definitely won't put 20K miles on it by then.) So I am not particularly panicked about it. In fact, my feeling is, if the battery/charging system isn't giving us really great performance, I'd just as soon as it goes sideways sooner than later (within the warranty window) so we can get a new battery on the house.
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I have a 2009 Gen II which I bought used (88k Miles on odometer) back in Jan 2014. You might read up about Prolong Grid Charging (see other threads and https://hybridautomotive.com ) Good luck - Wil :)
    BartonGDawes likes this.
  3. BartonGDawes
    Colorado
    Thanks, Wil. I will look that product up. But I'm not still clear if my battery level fluctuation is pretty standard (actually, it seems to be the same as the other 10 used Priuses I drove), or if it sounds more "rapid' than usual.
  4. WilDavis
    2,492
    2,153
    49
    I've noticed that use of the A/C seems to make a big difference in the state of the Traction-Battery charge. The SoC will drop to 2 purples pretty quickly, but it doesn't take much driving to get it back up to all-greens. My Traction-Battery seems to be in good shape. I've been using the Prolong Grid Charger since Jan 2016, so perhaps it has made a difference, but without access to another Prius (with an un-conditioned TB) it is difficult to make a comparism (as it often is in the case of preventative maintainance!) - it is just insurance, after all - and my 2009 Gen II has just rolled over 114,000 miles, so it's in about the right ball-park for it's age and wear on the TB) ;)
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Barton, your battery's behavior is normal. Fluctuating between fully charged and fully discharged in a very short time is one of the symptoms. If the ICE constantly runs trying to charge the battery is another symptom.
    WilDavis and BartonGDawes like this.
