What Is "Normal?"
Discussion in 'Gen 3 Prius Main Forum' started by Maine Pilot, Mar 31, 2011.
  1. Maine Pilot
    Maine Pilot Senior Member
    166
    504
    Saco, Maine
    Just purchased my 2011 Prius II 6 days ago and now I'm here with my first post.
    I've gone through quite a few threads here, trying to get a better "feel" for the car and owner's concerns. In several instances, posters have stated they operate the car in the "Normal" mode, as opposed to "Eco." Funny, I don't seem to have a dashboard button for that mode. Is it something that's found on earlier generations, or am I missing something? All I see are buttons for "EV, Eco and PWR." My car salesman recommended using the "Eco" mode for normal driving.
  2. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Normal is the absense of any of the other buttons being pushed .... the default so to speak.
    REV
  3. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    What REV said. No ECHO light=NORMAL mode, NO PWR light=NORMAL mode, No EV light=NORMAL mode. You get the idea.
  4. ETC(SS)
    6,581
    Re: What Is "Normal?"
    Around here? That's a heckava good question!
    Welcome aboard! :welcome:
    As you drive your car, read the 600-page manual, and then sleep off the induced drowsiness, you'll begin to discover what is 'normal' with your driving habbits in this car.
    Try to keep the 'worry' switch in the "do not" position, and enjoy the car and it's $30-every-500-mile fillups!
    If you find that you cannot read more than 50 pages of the owner's manual without the Sandman pouring sleepy dust into your eyes, then do some reading in the forum. It's always good for a chuckle or two and I think that you'll find that most of the "Why does (doesn't) my car do this?" questions are (best) answered with:
    "Relax. It's normal."
    EDIT: I always drive in ECO. When you place the car in this mode (as opposed to PWR and EV) the car will thence default to this mode until/unless you switch back out of it---then it's back to "normal". EV mode is pointless, unless you want to move the car w/o starting the engine, or you're trying to sneak up on your neighbor's cat (it never works...they always hear the tires.) PWR mode doesn't give you more power---it just remaps the throttle requests from your right foot. Like I said....RTFM. (read the *ah* factory manual...)
    Good Luck!
  5. ncfishboy
    ncfishboy New Member
    23
    KDH NC
    "There is nothing worst in this world than being normal"
  6. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    As mentioned, normal is when you're not in PWR or ECO, thus no lights lit.
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Congrats on your new Prius and welcome to PriusChat. Enjoy the high MPGs, technology and Prius fun.
    I drive my Prius only in ECO mode. The owner's manual recommends ECO mode as one of a couple means of achieving higher MPGs. Like everyone else said, NORMAL is the absence of any other mode.
  8. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    I also run the car in ECO most of the time.
    If I want quicker cabin warm up or cool down in hot or cold weather, I run briefly in NORMAL (POWER should also work)
    If I want a more sensitive accelerator pedal (eg merging onto a crowded freeway from an old on ramp that is far too short), I will put the car in POWER briefly.
    For the rest of the time, I think that the better fine control of power application available under ECO is a benefit that makes other cars seem antiquated.
  9. amorris
    amorris Junior Member
    57
    Dallas TX
    Really, there is nothing "normal" about the Prius. It is exceptional in every way.
  10. bisco
    49,694
    i'd say once a day, but it depends on your age.:D
  11. Prius O Matic
    Prius O Matic Junior Member
    Tampa Fl
    It's a small town in Illinois near Bloomington.
    I like the "worry switch" in the "do not position" comment. After two car payments worth of ownership I am finally getting a little less obsessive about squeezing every-single-bit of mileage out of it and just driving the car. If I drive oblivious to what mileage I am getting I usually lose about 3 MPG during my morning commute to work.
  12. twittel
    1,605
    148
    Mt. Pleasant, SC
    Then I'm very normal, but a dried prune helps.:)
  13. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    What others said. If your car is in ECO mode, pressing ECO again will toggle it off and put the car back in "Normal" mode.
    ECO makes the car a bit more conservative with the climate control.
    A regular German PriusChat poster has suggested that in ECO there's some difference in how the car behaves while driving at different speeds, but the main difference is really just in the response to gas pedal travel. ECO gives you more precision at the low end, meaning that it's easier to avoid unnecessary acceleration and regeneration, with the trade-off being that you have to press the gas pedal down further for a change in required power.
    I ECO, my wife PWRs.
    Congratulations on your new car.
  14. joemiata
    joemiata New Member
    New Jersey
    I Love this site, you guys are funny :D
    So, by the way what does the car do differently in the "normal" mode. I've been driving in Eco and I too am obsessed about mpg. But I'm sure I'll calm down after a while. Had the car since Mon. today is Fri. I'll play more with it this weekend.
    Joe
  15. ItsNotAboutTheMoney
    2,287
    460
    Maine
    A less obsessive way is only to try to avoid unnecessary braking and acceleration instead. That'll become more automatic and you'll still save gas, tires, brakes and engine wear.
  16. twittel
    1,605
    148
    Mt. Pleasant, SC
    From reading threads, I've discovered that ECO mode may not provide enough a/c compressor support for those really, really hot/humid days, but I've not seen evidence of it. I always stay in ECO mode and I'm comfortably cool on hot summer days. I assume that ECO model tries to cycle a/c compressor on-off more frequently while NORMAL mode keeps compressor on longer. It's all an effort to maximize MPGs. So with that, said ECO/NORMAL modes may be more than accelerator pressure sensitivity.
  17. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Once a week would be outstanding.. could you talk to my spouse please :D
  18. twittel
    1,605
    148
    Mt. Pleasant, SC
    How do you people do that once a week thing? It's like trying to only drive the Prius once a week; just can't be done
  19. bisco
    49,694
    ya, that wouldn't work for me. i'd have to walk the other six days.:) and oysters work better than dried prunes.:rockon:
  20. ItsNotAboutTheMoney
    2,287
    460
    Maine
    Seems like you have little to lose. You might as well go ahead and buy that Prius.
