What is Orange Triangle with Exclamation point mean?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Andy Dates, Sep 21, 2015.
  1. Andy Dates
    Andy Dates New Member
    Pasadena, CA
    I see this flash a couple times starting this weekend. It flashes, and goes away. What is it?
    Thanks.
    51,155
    might be a faulty 12v, but it's not indicative of anything in particular, just that you need to have the codes read.
    it can also be used roadside, when you're fixing a flat.
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    low oil level? Gen II did that in curves.
    Mendel Leisk and bisco like this.
  4. Andy Dates
    Pasadena, CA
    This is for 2010 Gen 3. What does that symbol officially stand for?
  5. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    If your car is still on the original 12v auxiliary battery, it's probably time for a new one. A low 12v can cause various types of warning lights and symptoms, or none at all before dying for good.
  6. dorunron
    3,318
    1,105
    Houston, TX
  7. dorunron
    3,318
    1,105
    Houston, TX
    If you are using that 14 volt battery... latest thing from Sonic Electronics. Full 14 Volt AGM Battery. Adjustable posts too, :LOL:
    Sorry for getting off topic folks...
    #7 dorunron, Sep 21, 2015
  8. Mendel Leisk
    40,586
    ^ @Andy Dates, did you check the dipstick yet?
  9. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    MSRP – $459.99
  10. bisco
    51,155
    worth every penny for two volts.;)
