What is that little light for?
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Aug 2, 2018.
  1. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    On the ceiling to the right of the courtesy lights switch is a small hole with a white LED deep inside. What is that for?
  2. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    It shines a light down on the gearshift lever?
    SeattleBicycler, Mark57 and schja01 like this.
    52,386
    yep, some people put tape over it.
  4. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Interesting. Thanks.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Yap, "Shift lever lighting" in the figure #3.
    schja01 likes this.
  6. Mark57
    2,945
    2,740
    OK
    Some of us ;) filled the knob with bright glow powder on our 2010's. illuminate the joystick shifter? | PriusChat It was a cool little mod. No the LED is not bright enough to charge the glow powder.
  7. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    Never noticed that. Does it come on by itself?
  8. Mendel Leisk
    41,898
    IIRC someone was saying the little floodlight for the shifter was a bit off, centred on a spot slightly further back.
    There was speculation that it was aimed at shifter location in an earlier 4th gen iteration, before a centre console was nixed and the shifter moved to the lower dash.
    Just speculating.
  9. huskers
    2,546
    2,487
    Nebraska
    Are we sure it is not Big Brother?????????? The "All Seeing Eye"?
    walterm and priuscatprimeguy like this.
  10. Mark57
    2,945
    2,740
    OK
    Not if you watch it . . . . :D Yes
    benagi, huskers and priuscatprimeguy like this.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Never. Ever. Look at that light.
    huskers, walterm and priuscatprimeguy like this.
  12. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    why? because you will go blind?:cool:
    huskers and fotomoto like this.
  13. fotomoto
    5,639
    3,815
    So. Texas
    No. That's doing something else!:p
    priuscatprimeguy, benagi and huskers like this.
  14. Trollbait
    12,679
    Mmm, my 2006 HHR had such a light.
  15. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    It's not always on.
    Each of the two times I've noticed it the cabin was dimly lit.
    Maybe the same sensor that dims the instrument displays?
  16. Tideland Prius
    16,615
    Yes it comes on with the parking light (or headlights if you're in AUTO).
  17. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    Just a courtesy light to give you a small amount of light so it's not so dark you can't see a thing. There is one at the feet also. I remember seeing an option to turn it off somewhere. Might have been when I was using the Carista hooked up to the computer port. Carista OBD2 App | Diagnose, customize and service your car
