what is that little slot for below the driver vent (left hand)
Discussion in 'Prius v Main Forum' started by ltlurker, Jan 31, 2017.
  1. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    there's a little slit (black) that's right below the vent on driver's left hand side. what is it for? doesn't fit anything including coins.
  2. cbydesign
    cbydesign Junior Member
    29
    Michigan
    In the manual, it's labeled as a "card holder" pretty much useless if you ask me.
  3. mikefocke
    3,967
    1,792
    Sanford, NC
    I use it for calling cards to hand out when I witness an accident. Others use it to store a parking pass. Not much else you can put there.
  4. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    yeah, totally useless then.
  5. black Sunshine
    black Sunshine Junior Member
    Atlanta
    well i'm glad for this thread, because i ALWAYS lose my parking lot tickets . . . used it last night, worked like a charm!
  6. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
    Also works good for punch cards like car washes.
  7. mikefocke
    3,967
    1,792
    Sanford, NC
    Condensation from the A/C vent will drip down onto that slot. I notice the top of my stack of calling cards has ink smeared by this effect and is slightly curled. I don't know under what conditions this happens.
    So don't put anything in the slot that is paper and valuable.
  8. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    If you use A/C with recirculation inside of cabin this will be normal....including fogged rear window when there is not very hot or day....
    All car's will have this effect
    Condensation will also happens when there is high humidity and prolonged use of A/C....
    Try to stay out of Cabin recirculation unless is necessary if you standing still....
    Not very good to use if you drive with this option on
