What is the 12 volt battery for?
Discussion in 'Gen 2 Prius Technical Discussion' started by toad, Jan 28, 2007.
  1. toad
    toad New Member
    This may be a stupid question but why does the prius have a 12 volt battery rather then power everything from the traction battery? I understand the 12 volt battery powers the normal things (radio, headlights, etc.) but why can't you power this from the hybrid battery?
    Thanks.
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(toad @ Jan 27 2007, 09:18 PM) [snapback]381852[/snapback]</div>
    short answer is, it's used to boot the computer which closes the HV relay which then powers the car. Also the 12 volt is charged from the inverter so in reality it's charged from the HV battery.
  3. Orf
    Orf New Member
    414
    Devonport, Tasmania
    Written on my battery are words to the effect that it powers the brake system.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    In addition, having a separate 12V battery allows the traction battery to be completely disconnected when the car is shut down, preventing a costly total discharge in the event a door was left open or something like that. Furthermore, the inverter would have to run to power any 12V items, such as lights and the radio, unless you want to have purpose designed lighting and electronics, plus high voltage wiring running around the car.
    Tom
  5. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(Orf @ Jan 27 2007, 10:12 PM) [snapback]381868[/snapback]</div>
    and the power steering
  6. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(qbee42 @ Jan 28 2007, 08:04 AM) [snapback]381932[/snapback]</div>
    This is the real reason.
    If you ever have to replace the 12v battery, thank your lucky stars it wasn't the traction battery. Toyota engineers went to amazing lengths to protect the traction battery. We need to be grateful that they did.
  7. duanelaugh
    duanelaugh New Member
    57
    Bradenton fl area
    <div class='quotetop'>QUOTE(Allannde @ Jan 28 2007, 01:39 PM) [snapback]381983[/snapback]</div>
    Excellent answer!!!!!!!!!!!!!!!!!!
  8. toad
    toad New Member
    Thanks everyone. :)
    All are very good points. I guess it would be very bad to have the traction battery completely drained.
