What is the Amp hour rating of the HV battery pack
Discussion in 'Gen 2 Prius Technical Discussion' started by priussoris, Aug 28, 2007.
  1. priussoris
    priussoris New Member
    1,005
    I think I have seen this somewhere but can't seem to find it.
    what is the Amp hr rating of the 07 prius battery pack?
    <div class='quotetop'>QUOTE(priussoris @ Aug 28 2007, 04:00 PM) [snapback]503417[/snapback]</div>
    Found my own answer:
    Feature Model code
    NHW10 NHW11 NHW20
    Body style 4 Door
    Sedan 4 Door
    Sedan 5 Door
    Hatchback
    First sales 1997 2000 2003
    Battery Modules 40 38 28
    Cells per module 6 6 6
    Total cells 240 228 168
    Volts per cell 1.2 1.2 1.2
    Total volts (nominal) 288 273.6 201.6
    Capacity amp hours 6.0 6.5 6.5
    Capacity Watt hours 1728 1778.4 1310.4
    Weight kg 57 50 45
    Petrol Engine Power kW 43 52 57
    Max rpm 4000 4500 5000
    Electric Motor Operating Voltage 288 273 500
    Power kW 30 33 50
    Combined Power kW ? 73 82
  2. Doc Willie
    1,717
    142
    Out there, somewhere
    According to the flyer on John 1701a's site, the battery pack is rated at 6.5 Ah total.
  3. McShemp
    McShemp New Member
    371
    SA, TX
    That's it.
