What is the average mpg if you charge it once per fill up?
Discussion in 'Prime Main Forum (2017-2022)' started by seeforyourself, Feb 24, 2021.
  1. seeforyourself
    seeforyourself Junior Member
    36
    New York City
    Three Touring
    I am not sure if I would plug it in everyday, but what if I plug it in and charge it every tank? What would the mpg be?
    Thanks!
  2. MTN
    MTN Active Member
    306
    276
    SB, CA
    It would add 20-30 miles of "999.9" mpg to your tank. So it depends on how many miles/gallons your normal tank use is.
    easy math examples:
    Lets say you use 10.0 gallons and get 54 mpg, with no EV plug in = 540 miles
    If you get 570, with 10.0 gallons = 57 mpg
    If you get 560 = 56 mpg
    etc
    Salamander_King likes this.
  3. Trollbait
    12,460
  4. Salamander_King
    Salamander_King Senior Member
    11,010
    8,940
    New England
    As said above, it only adds ~25 miles of "gas-free" miles on your tank full of "gas-only" miles. For a full tank, it won't change the overall mpg that much. A few mpg better than without charging, as indicated by @MTN and @Trollbait .
  5. Washingtonian
    Washingtonian Senior Member
    726
    621
    I was going to say that if you only charge once per fuel fill-up you shouldn't be buying a Prime. But on reflection, even if you never charge it yourself, I believe it is still a better car than the standard Prius.
    Sarge, DavidA, schja01 and 3 others like this.
  6. Salamander_King
    11,010
    8,940
    New England
    And where the OP is located, Prius Prime is cheaper than the standard Prius after rebates and other incentives are applied. Hard to convince anyone to buy a standard Prius unless he/she really needs a flat deck with the ability to store a spare tire under the deck. I think the lowest trim standard Prius still comes with a spare, but all others do not.
    MTN likes this.
  7. MTN
    MTN Active Member
    306
    276
    SB, CA
    Agreeing with above - if the OP is in NY, the rebates/credits offered on a new Prime bring the price down to be much lower than a "regular" Prius and make it a great deal, if they wish to buy a new vehicle. Whether the are even able to plug it in or not, is secondary. It can be used as a hybrid with a large battery, just fine.
  8. RovinRon
    RovinRon Junior Member
    33
    22
    Federal Way WA./Sun City AZ.
    We brought our Prime down from the Puget Sound area to the Valley of the Sun in Sept. No charging on trip, still got 60 mpg! Haven't filled the gas tank since we filled it up after we got here! Love it!!
  9. Tideland Prius
    16,528
    I honestly believe the Prime will handily beat the Prius Liftback in HV MPG. I got 53mpg at 70mph in our Gen 4 Touring (similar to a US Three Touring). A Prime will be closer to 60mpg (a 2019 trip across the Cascades and back and includes 3 full charges netted 65mpg.
    Around town, 65mpg is possible (starting with now charge) and as high as 75-78mpg if temperature, traffic and terrain are favourable.
    jerrymildred and Salamander_King like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Same results here.
    I've driven my wife's '17 trim 2 and my '17 Prime in HV on the same 40.1-mile round trip route several time. The Prime always gets better mileage.
    Tideland Prius likes this.
  11. Sarge
    Sarge Senior Member
    1,324
    778
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I agree. I see only ONE reason to opt for the regular Prius over the Prime, and it is a weak reason at that:
    - considerably larger cargo area
    However, I call it weak since there is a simple solution when more cargo is needed, which is to just attach a roof box when the 20 cu ft is not enough, like when travelling. However, how many people use the full 20 cu ft on a frequent basis anyway? This capacity is very similar to an average sedan anyway, it is just not a huge cave like Prius has been known since 2004.
    Price could be another factor, but as others already mentioned, depending where you live, it could actually be CHEAPER with incentives. So definitely a no-brainer for those people...
    Cheers.
    MTN likes this.
  12. Tideland Prius
    16,528
    There's also AWD-e. Most of the new ones I see are AWD-e. FWD ones are from a local car share.
    Sarge likes this.
  13. Trollbait
    12,460
    Roof rack is an option, but it is one that comes with an efficiency hit, specially on the highway. Using one also pushes the maintenance schedule into the severe category.
  14. Sarge
    Sarge Senior Member
    1,324
    778
    2023 Prius Prime
    XSE Premium
    Good catch, I forgot about that. Yes, that would be a 2nd good reason. :)
  15. Sarge
    Sarge Senior Member
    1,324
    778
    2023 Prius Prime
    XSE Premium
    Sure, it would be a small efficiency hit, but for the occasional use (a couple times a year), this would surely be a reasonable trade off, IMO. If it becomes a situation where it is needed frequently, I doubt the extra 6-7 cu ft would be the difference, and perhaps a RAV4 Hybrid/Prime (or Highlander / Sienna) would be a better option for that person. ;)
    MTN likes this.
  16. Trollbait
    12,460
    But the point of choosing a hatchback is to have more cargo carrying options than a sedan.;)
    Sarge and jerrymildred like this.
  17. Sarge
    Sarge Senior Member
    1,324
    778
    2023 Prius Prime
    XSE Premium
    Sure I don’t disagree and love hatchback design, but I think we have beaten this one to death now. :LOL:
  18. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    One charge per tank is going to help you maybe 25 miles per tank. That's roughly 5 percent additional on the gas mileage. If you are like me and charge twice daily. You'll be adding a bit. But I typically do 140-200 miles a day. So the additional is more like getting 650 to the tank.
  19. Tideland Prius
    16,528
    You'd think but I have noticed locally that roof top boxes are becoming popular with more owners opting to use one (instead of buying a bigger vehicle).
    Oddly enough, they're mostly on wagons (V60, A4 allroad, older Passat wagons, Golf wagons and Golf AllTracks). Weirdly enough, I haven't seen many (if at all) on Outbacks. There are a few on Prius and Primes. Those on Imprezas are usually ski attachments rather than roof top boxes.
    Sarge likes this.
