What is the "B"?
Discussion in 'Gen 3 Prius Main Forum' started by RLE88, Mar 5, 2012.
  1. RLE88
    RLE88 New Member
    NNJ
    Hi All,
    I am the proud new owner of a 2011 Prius 2. So far I am loving the gas mileage I am getting. I traded in my 2011 Rav4(Only owned it for a year), because of the gas mileage difference between the 2 vehicles. I have a "Newbie" question...How and when do you use the "B" on the gear shift? I understand that it is "Brake"...but when is it beneficial to use it? Thanks for the anticipated answers!
  2. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    This is a wonderful design of Toyota. During traffic jam, moving inch by inch, you can swift to this gear. Step the gas paddle, car moves forward and when you release the paddle, the engin will do the braking for you(without burning any gas!). No need to step on brake unless you need to stop the car at that spot. It's a very useful design. Don't know whether Toyota got patent on that.
    Enjoy. :cheer2:
  3. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Use it for engine braking. Basically, if you are driving down a steep decline (like down a steep mountain road), you can put the car into "B" mode and it will give additional engine braking.
    It works much like "2" in a 3 speed automatic transmission. It allows you to not use the brake pedal as much and reduces your coasting ability.
    I have only used mine a few times, and each time it was descending the Santa Cruz mountains. You may never use it and it may never need to be used.
    I wouldn't use it in normal driving regardless of conditions.
  4. Tideland Prius
    16,155
    Treat "B" as "L" or "2" on a regular automatic transmission. You use it for additional engine braking (e.g. descending a long hill to relieve some pressure off the brake pads). Under 40km/h, it has a stronger regenerative braking effect (but no different if you were to press the brake pedal harder). Above 40km/h, the engine will come on and pump the pistons to provide the engine brake (or jake braking) to help slow the car down. You want to minimise this since you'll be losing speed due to friction in the engine rather than capturing all of that momentum by using the brake pedal instead and recharging the battery and still keeping the engine off.
  5. RLE88
    RLE88 New Member
    NNJ
    WOW! That is great! I drive thru the city of Newark NJ every day. I will be using the "B" often! Thanks!
  6. kpbuckley
    kpbuckley New Member
    Rhinebeck, NY
    Congrats on your new car!! I also just traded in a gas guzzler (Subaru Outback 3.0) for my first Prius. At any rate, I was told that the "B" is for when you are going down long declines (like in the Rockies or going over the Grapevine in California). I really don't know too much more, but was told most people will never need it.
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    No, that is an "incorrect" use of "B". It wastes the energy you could otherwise recover using regenerative braking.
    ahmeow needs to be "educated". ;)
  8. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    "B" is just a waste of your time in traffic. Most likely you will forget you have it in B and its use will decrease you gas mileage. It's for use in really long steep downhill roads that you don't have in NJ.
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If your regenerative brakes fill up, then you must have friction brakes, B mode adds engine braking, so your friction brakes do not heat up too much.
    Because a Prius has no lower gears, someone at Toyota was too honest to call it L, but you use it when you would use L.
    Above about 20 MPH, it is considerably more wasteful than just using the brakes, so use it when you want to waste energy, long steep descents. It is possible there are no long steep descents in New Jersey, so you may never need it. http://en.wikipedia.org/wiki/High_Point_(New_Jersey)
  10. fuzzy1
    10,170
    Newark's maximum elevation is 273 feet. B isn't useful until steep mountain descents exceed about 500 feet, and isn't really necessary without considerably more descent.
  11. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Yes, but the effect is minimal to non-existent on steep grades. There just isn't enough compression to counter gravity on steep grades. I know that the Catalina highway to/from Mt. Lemmon in Tucson averages a 5% grade. No way does B even come close to slowing the car on descent. I charge off after a few miles and the rest of the 15 miles is friction. Oh, but the display does look really nice after the trip down.
  12. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I definitely felt B on the Tail of the Dragon, but I think it is quite a bit more than 5%
  13. HaveNoCents
    HaveNoCents Conservative Tree Hugger
    299
    47
    Crystal Beach, Texas
    I remember my salesman told me the B stood for battery. Now there's a guy who needs to get a little more product knowledge.
    iPad ?
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    hmm ... my experience is different.
    I can think of one specific moutain I drove down frequently from Los Alamos that absent braking would quickly lead to dangerous speeds, but taking my foot off the fuel pedal in B mode not only prevented the car from gaining speed, the car would slow down.
    To the OP in NJ: you will never have a good reason to use B in your state.
    The advice to use it in stop and go driving might save the occasional trip of your foot from the fuel to the brake pedal, but the cost is lost regen. Keep a longer following distance instead, and coast more.
  15. AZGeek
    627
    144
    63
    Arizona
    Cool elevation map. Looks like roughly 2000 feet over 11 miles.
    The example I gave was perhaps a bit more extreme --- roughly 5000 feet over 20 miles.
  16. AZGeek
    627
    144
    63
    Arizona
    Thanks, SageBrush. I think the difference is the definition of "steep". I have no problem getting the car to slow down on lesser grades and the point I was trying to make is that it doesn't add much to steep descents; especially not as a substitute for friction braking.
  17. fuzzy1
    10,170
    Is that a very slow section of road, with little air drag?
    B does the job for me on 7% grades at highway speeds, though the engine is howling. At 5%, I need to press the gas pedal a bit to slightly reduce engine drag.
    On steeper hills at slower speeds, e.g. 8% at under 20 mph coming down Pikes Peak, then B is insufficient. It may be equivalent to downshifting a 5 speed manual to somewhere between 4th and 3rd gear. On hills needing 2nd or even close to 3rd gear, B is inadequate, and a B2 would be helpful.
  18. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Hello David,
    I know the B can be use as 'L'. However you will find it the best time to use is during traffic jam going inch by inch. Of course normal traffic will never use it, wasting alot of energy. Decending deep slope is also helped by it. But still need to use the brake. Use during traffic jam is the best.
    Try, have you?:)
    Regards.
  19. fuzzy1
    10,170
    If you want to use it as a driving style, this won't hurt anything except a slight hit to MPG. But for maximum MPG, this use cannot beat simply using the brake, and cannot match a traffic-coordinated pulse & glide.
  20. SageBrush
    11,627
    2,530
    Southwest Colorado
    I decided to attempt a gross calculation of the *minimum* braking B mode is exerting in the route I mentioned. I looked up Google maps and Google Earth for distance and altitude data for the road highlighted in yellow below
    I've assumed 30 mph, and no change in speed
    100 meter drop
    0.8 mile route
    Drop in potential energy in joules is m*g*h = 1400*9.8*100 = 1372000 joules, equal to 0.381 kwh = 381 wh = 22860 w*min
    The route takes 1.6 minutes, so the power dissipation is 22860/1.6 = 14 kw. That is a *very* conservative calc; my WAG is actual drag for that speed is at least double that amount.
