What is the BEST tire pressure, for 3k mile mostly HWY trip?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Aug 2, 2018.
  1. ski.dive
    ski.dive Active Member
    896
    231
    Hutchinson Island,FL. Mt. Snow,VT
    What is the BEST tire pressure, for 3k mile mostly HWY trip?:)
  2. PlugmeInplz
    PlugmeInplz New Member
    22
    24
    LA
    2013 Prius Plug-in
    I like to keep my tires at 40 PSI. When you drive HWY the temperature of the tires will cause the pressure to increase. So they might get to 42 PSI after a long drive. I typically drive 75-85 MPH on interstates.
    ITBland and nssdiver like this.
  3. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    656
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
    We are doing another 7,000 mile 3 week run. Recommended 36, I run 38 PSI. A compromise for ride, load and mileage.
    #3 bat4255, Aug 2, 2018
    srellim234 and PlugmeInplz like this.
  4. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    We alternate our trips each year between going to Utah + Colorado (3k miles) and going to North Carolina (5-6k miles). We're running 38 front, 36 rear on our trips at 70-80 mph speeds. We originally bumped them up to 40 but the ride was a little too stiff for our liking. We haven't seen any real change in mpg lowering it back down a few psi.
    Starship16 likes this.
  5. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,612
    Somewhere in Wisconsin
    2013 Chevy Volt
    Sidewall max unless you are driving off-road
  6. bisco
    49,492
    mfg recommended. don't need a blowout on the highway.
  7. Patrick Wong
    18,200
    6,474
    What is your definition of best?
    If you want to maximize tread life and enhance fuel economy, use 42/40 psi. This will promote even tire tread wear.
    If you want a softer ride, use mfr spec of 35/33 psi. This will usually result in faster tire shoulder wear.
  8. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    At highway speeds, I am thinking wind resistance takes over from tire pressure (rolling resistance).
    So I am starting to think high tire pressure helps more on the driving we do (around town slow).
    nssdiver and srellim234 like this.
