What is the best way to warm up a Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Apr 24, 2015.
  1. Preeeus
    Preeeus Member
    255
    59
    With a conventional gas-only vehicle, many people recommend letting the engine run for a short while before moving. In moderate climates, 10-30 seconds is considered enough.
    The Prius, of course, is no ordinary vehicle!
    When you start your Prius, the ICE (Internal Combustion Engine) does not start immediately when you turn on your car. I haven't timed it, but I would say it starts 5-10 seconds later.
    When starting a Prius in moderate climates, is it best to wait for the ICE to turn on, and let it run for a short while, before moving? Or is it fine to just press the power button and take off without waiting for the ICE to warm up?
  2. Preeeus
    Preeeus Member
    255
    59
  3. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Just drive. No waiting required.
    xpcman and Mendel Leisk like this.
  4. Mendel Leisk
    38,717
    Yes, just start and go.
    I have timed the electric-only grace period at startup, well informally, just counting: seems like about 15 seconds. That can get the car from garage to driveway, or vice versa.
    Our first cold start any day is invariably proceeded by plugging in the block heater, Two hours seems a good time.
    Once rolling, like any gas engine, just take it extra easy, for the first few blocks.
  5. bisco
    49,469
    i have a few miles to the freeway, so i start and go, taking it easy on the warm up. if i had to power right up, i'd turn the heat up so the engine runs for a few minutes before hitting the highway.
  6. bisco
    49,469
    see my reply to your other thread.;)
  7. Mendel Leisk
    38,717
    Bisco's in a plug-in, so sometimes there is no warm up. :)
  8. bisco
    49,469
    even better.(y) except when the windows ice up.(n)
  9. Preeeus
    Preeeus Member
    255
    59
    Oops... somehow I posted this twice. I don't know how that happened. I started creating it in this forum, and then realized the Care Maintenance and Troubleshooting forum was a better place, so I cancelled posting this thread and posted it over there. Somehow it still got posted here!
    Mods, my apologies, and please feel free to delete this thread, as it is correctly posted in the Care Maintenance and Troubleshooting forum.
  10. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    In ANY modern vehicle, 10 seconds is plenty.......for the engine, unless it is REALLY cold, then maybe 20 seconds. :)
    Anything beyond that is for "creature comfort".
    OK, one exception:
    If it is necessary for you to FLOOR the pedal immediate after leaving your driveway, then you might want to let the warm up cycle finish; or with a conventional car, give it a couple of minutes.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    With The Prius I just go.
    The eCVT transmission is going to keep the most efficient RPM's possible. I think The Prius has more built in checks and balances on "what" it's doing than most cars given it's hybrid HSD system. It's designed to warm itself up and know when it's warmed up.
    Couple that with the required 0 weight oil, and I worry less about warming up The Prius than probably any other vehicle I have ever owned.
  12. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Keep in mind that you're running mostly on battery power during the initial stage of warm-up, unless you push the go pedal hard, which supposedly ain't good for the cold engine.
  13. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
  14. bisco
    49,469
    and getting longer.:p
    WolfpackBill likes this.
  15. WolfpackBill
    349
    500
    Lexington, NC
  16. bisco
    49,469
    and a good reason to try and arrive home with a full battery. use the ice when it's hot, and the battery when it's cold.
  17. qdllc
    qdllc Senior Member
    1,370
    399
    Start and go. At best, just avoid going to far into the "ECO" range until the system's warmed up. Yeah, the gas engine is running, but just to warm up...no real demand it being placed on it for propulsion. Once you're warmed up, you can peg the meter into the PWR range to your heart's content. :cool:
