What is the correct tire pressure for Gen 4 195/65R15 91H
Discussion in 'Gen 4 Prius Technical Discussion' started by booke02, Jul 12, 2016.
  1. booke02
    booke02 Active Member
    391
    415
    Israel
    Picked up my Gen 4 this week, which has a full-size spare. Door sticker and dealer say that standard tire pressures are 36 front and 35 rear.
    In the European (English) manual, they give two sets of recommended tire pressures for 15" wheels, depending on whether you have a full-size spare or not. Doesn't make much sense to me that the tire pressure should be dependent on the type of spare that you have (unless the tires on the car are also dependent on the type of spare.
    The manual also recommends side-to-side/front-to-rear rotation
  2. Tideland Prius
    16,128
    It could be a different set of tires but also the full size spare tire will also balance the weight distribution of the car, adding more to the rear. This is why the recommended pressures are equal all around (32 psi) versus a slight front bias (36/35 psi) for those without the full size spare tire. In North America, we only get the compact (temporary) spare tire or the tire repair kit so our manual only has the 36/35 psi for *most* 15" wheel models. The only exception is the Prius Two Eco model which runs 39/36 I think but it has special tires.
  3. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    It's the same in the German manual (actually I was told for another reason, that the manuals are all the same and translated from the same source, derived from the Japanese one....). This is why for example mine says that I can check the washer fluid with a dipstick, when in fact there is none and none is provided, at least in Germany....
    The differences of tire pressures are actually quite unsubstantial. I have my 17" set at 2.6/2.5 bar F/R, instead of the recommended one for 3 reasons:
    1) when you pump them, some air gets out when I remove the valve after inflating
    2) I don't have to check the pressure *every 2 weeks* as the user manual states, rather every 1-2 months without worrying they will be underinflated, which is worse than overinflated IMHO
    3) I should get better MPG, a possibly a tad less grip
    So honestly, I'd set them to 2.5 overall and forget them for a couple of months. I don't think that 0.3bar difference, assuming one could pump them all precisely at this level, will make any difference whether you have a full spare or not at the back.
  4. booke02
    391
    415
    Israel
    Well, they got the Hebrew translation rather mixed up, and showed the same title for both variations of tire pressure.
    I was just curious to try and understand why the pressure recommendations were based on the type of spare.
  5. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    For vehicles WITHOUT a full-size spare, My Three model owners's manual (15" tires) shows a simple front-to-rear / rear-to-front rotation pattern. (No crossover.)
    And for models WITH a full-size spare, the rotation pattern in my manual is different than what booke02 posted. (No X crossover.)
    I wonder why all the inconsistencies??? Why is the North America owners's manual different from other parts of the world? Same thing with oil viscosity...
  6. booke02
    391
    415
    Israel
    The different rotation patterns could be because cars delivered to North America are fitted with tires that have fixed rotation direction. My car is fitted with Yokohama tires (very quiet), which can spin in either direction
  7. Coast Cruiser
    2,267
    2,571
    Thanks booke. It was interesting, (and confusing) when I was shopping for my 2016 Prius. I noticed all the non-touring models (Two, Two Eco, Three, and Four) were equipped with various tire brands:
    Yokohama
    Toyo
    Dunlop
    Bridgestone
    You could pick and choose. I saw 3 Red Prius with different tires. And 3 Silver Prius with different tires. All the White Prius seem to have either Toyo or Yokohama. A lot of the Silver and Black ones had Dunlop. (But if you step up to the touring models with the 17" tires, they all had Bridgestone.)
    And the tires on the Two "Eco" were no different than the other Prius models. The Dunlop or Yokohama tires on the Eco were also found on the other models I looked at. Same exact tire. (The Eco tire is just inflated a little higher, that's all. Nothing different about it that I could tell.)
    (And I have no idea if any of those tires are "non-directional", or directional, or whatever. :confused:)
    booke02 likes this.
  8. Mendel Leisk
    38,652
    I just finished watching Season 3 of Line of Duty (British Police Procedural). All I can think: if they got Toyota in the interview room for 10 minutes, discussing all the discrepancies, they'd be confessing to anything, lol.
    #8 Mendel Leisk, Jul 15, 2016
    vvillovv and booke02 like this.
  9. booke02
    391
    415
    Israel
    Now I am completely confused...
    vvillovv likes this.
  10. Mendel Leisk
    38,652
    The North American Owner's Manual stipulation to keep tires on one side wouldn't be due to tires being directional or not (most aren't I would think). Not sure what their rationale is.
    Coast Cruiser likes this.
  11. krmcg
    2,592
    2,390
    Whittier, CA
    Directional tires are clearly marked on the sidewall usually with a BIG arrow showing direction of travel.
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Toyota isn't purposely being confusing. The world is varied and different. Standards and rules are different in different places. Just because the car looks the same and has the same name doesn't mean they are identical beneath the sheet metal.
    BITOG forum will have finer details but the oil recommendation basically depends on temperature and fuel economy. There's different bumper height regulations. We see 4 cylinder cars pull trailers in Europe but not in North America. You think that's just a change in the North American manual by the lawyers? There could be structural changes in the car as well.
    We know Europeans like a firm sporty ride. (Or it's a myth they tell us Yanks.) Us fat Americans like a cushy ride, hence lower tire pressure recommendation plus whatever suspension optimization Toyota makes. Europeans like to pay their wait staff living wages so they don't have to pay tip. Americans likes to pay low income taxes so we can pay doctors instead of having universal health care.
    I think of tire pressure, rotation scheme, oil viscosity as Safari on your iPhone. Use it if you like, download another browser if you don't. Apple doesn't discourage it, however, they won't help you if you have a problem with Chrome, they will if you have a problem with Safari. In the US, we like football. The rest of the world likes football. It's the same name, but we play it a little differently.;)
  13. Coast Cruiser
    2,267
    2,571
    I haven't noticed any big arrow on my Toyo tires.... This time I checked them with a magnifying glass. No arrow; Made in 2015; (Japan); Treadware: 300; 2 steel belts/1 polyester; Sidewall 1 polyester; Max tire pressure: 44 psi. (Door placard says 36/35). I think 40 is a good compromise. And I will stay with the simple tire rotation of front-to-back.
    It must be my driving style, but I've never gotten more than 21,000 miles from a set of OEM factory tires. My 95 Camry had Goodyear, and my 05 Camry had Bridgestone. It will be interesting to see how the Toyo's do on my Prius.
    booke02 and krmcg like this.
  14. Coast Cruiser
    2,267
    2,571
  15. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
  16. mark27lim
    mark27lim Active Member
    108
    103
    singapore
  17. WeiW
    WeiW Junior Member
    BC Canada
    Technology
    Mine was fitted with Bridgestone Ecopia EP 422 Plus. Only had 500km so far so not sure how quiet and comfortable it would be. Interestingly the psi was 40 when I received the car from the dealer but they set it back to 36 psi when I did one month free inspection.
  18. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Prius Two Eco, as has been seen on this forum, has had some of the same tires as regular models.
    I'd set the tire pressure to your preference, using the Toyota minimum guidelines (so, 32 PSI all around it appears) as minimums, and the sidewall as maximums.
    I'm at 40.5 PSI front, 40 PSI rear, myself. I prefer a firmer ride, the higher pressure will keep it from rolling onto the sidewall in aggressive cornering, fuel economy will be improved, and it'll stay in the recommended range for longer.
    Trollbait and Coast Cruiser like this.
  19. Trollbait
    11,511
    I noticed the one side tire rotation in my Toyota manuals, while our domestic ones still have the crossover one.
    I wonder how much say the dealerships have in this.
    It's actually down to different trailer regulations, with the European ones resulting in less tongue weight on the car. So they can pull more weight, but have to stay below 60mph or the trailer will become unstable.
  20. booke02
    391
    415
    Israel
    I think this depends on what type pf tires are fitted. In Europe, the tires that are supplied can rotate in either direction. If you look at the tires of a Prius delivered to USA, I suspect that you will find rotation arrows stamped on the sidewall of the tires.
