What is the difference between...
Discussion in 'Gen 3 Prius Main Forum' started by handlebar, Jun 30, 2011.
  1. handlebar
    handlebar Junior Member
    23
    South Florida
    a generation II and a generation III? I have a Silver 2011 and I don't know what it is, other than one great car and I love driving it. So far my collective fuel economy for 3500 miles is 48.4mpg.
    If this is a dumb post, I hope you will humor my request, but I just don't know.
    I found the answer, 2010 and up is Gen III. But I have a 2011 Model II. That is what confused me.
  2. ETC(SS)
    6,537
    You have a G3. Or a Generation Three.
    They're the 10's, 11's, and (soon to be) 12's.
    There are 4-1/2 trim levels for the G3:
    II, III, IV, and V.
    There's a "I" that's supposed to be a "Fleet Only" vehicle that's a stripped down version of the G3-II, but they're like unicorns and the Plug In Hybrids (PHV).
    Everybody knows what they look like, and "some" people have seen them, but they're not what you would call 'common'.
  3. itonarely
    itonarely Junior Member
    36
    Miami
    Welcome aboard and enjoy your Prius.
    I purchased a 2011/Three only two and a half months ago and I had to go digging through my paperwork to find out what I had purchased after I got home.
    From this site I had already established that I had a Gen III but I had no clue as to what model I had purchased.
    From my experiences on this site, there are a great many things to learn about your new Prius but the most important thing is to enjoy your Prius while doing so.
    Have a good day.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    And for 2011, they change the naming of the sub-models from roman numerals. For example, I have a 2010 Prius V, but the equivalent 2011 model is called a Prius Five. So the OP actually has a Prius Two.
  5. ursle
    ursle Gas miser
    1,049
    192
    NH
    Gen 2 has McPherson struts in the rear, gen 3 doesn't
    Gen 2 has a 1.5motor, gen 3 is 1.8
    I bet there are a thousand differences
    :welcome:
  6. ETC(SS)
    6,537
    Yeah....I was going to mention that, but the OP is fairly new, and it would have involved a 500-word dissertation on the difference between Roman and Arabic numerals, and sparked a heated debate on the difference between capitalizations (is it Two, TWO, or two?) and the social acceptance of just using an Arabic numeral, along with a historical mention of the Prius v (station wagon) which, like the PHV I still haven’t seen yet.
    THEN a disgruntled V...or v...or Five....or 5 owner would have been offended somehow, and that would have sparked another 200 post blue-on-blue fight on how the "lesser" Prius owners are just jealous.
    Who needs all that?
    But yes.....you are correct....Roman numerals are now passe.
  7. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Toyota calls the 2010+ the '3rd generation' Prius (at least in my 2010 print brochure). I just call it 3rd gen.
    Gen III is too confusing with the trim numbers Two - Five which used to be II - V
  8. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    Look up everybody:rolleyes:. The heading of this forum is still "Gen III." And when asked, I still own a Gen III--Prius IV. Cripes!
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    A lot. See http://priuschat.com/forums/gen-iii-2010-prius-main-forum/88583-prius-versions.html.
    Yep, Toyota did. Everyone should out the words instead of using Roman numerals when describing the various trim levels of the 3rd gen. It helps avoid confusing between the Five vs. the soon to be released Prius v wagon.
  10. Tideland Prius
    16,122
    Here's what I've got so far. Note that not everything is applicable to the US version but most are
    New Features for 2010 across the world
    • EV/ECO/PWR Modes
    • Rear Disc Brakes (NA models)
    • Aerodynamic Front Wipers
    • Active Front Headrests
    • Telescopic Steering Wheel
    • 1" of travel added to driver's seat bottom adjustment
    • Height adjustable driver's seat (NA models)
    • Driver's Knee Airbag
    • One-Touch (Auto Up/Down) Power Windows
    • Variable-Speed Power Rear Windows
    • Illuminated Power Window Switches
    • Touch-Sensitive SKS Locking Function
    • Programmable Automatic Door Locks (Drive-Away Function)
    • Touch Tracer
    • Peak of Roof moved back 3.9" (99mm) to increase headroom
    • Scuplted front seatbacks to further increase rear kneeroom
    • Nearly Flat Rear Centre Hump
    • LED taillights
    • Re-tuned suspension
    • Extended Underbody Strengthening Brace
    • Underbody Fins for Airflow Management
    • New Multi-Information Display (Eco Drive Monitor) with Consumption History
    • Hybrid System Indicator
    • Hill-Start Assist
    • Heads-Up Display, HUD (Europe/Japan)
    • HDD Navigation (Europe)
    • 10GB Hard Drive Music Box (Japan/Europe)
    • Rear Seatbelt Display (Europe)
    • XMNavTraffic on Navigation System (NA)
    • Emergency Stop Brakelight Feature
    • Available plasmacluster ionizer (US)
    • Exhaust Heat Recirculation System (replaced coolant thermos)
    • Cooled Exhaust Gas Recirculation
    • Electric water pump
    • Beltless 1.8 litre 2ZR-FXE DOHC VVT-i inline-4 cylinder engine
    • More efficient electric A/C compressor
    • "Aero" corners (sculpted front/rear bumpers for aerodynamics)
    • Acoustic windshield
    Taken from here:
    http://priuschat.com/forums/knowled...andard-optional-equipment-some-countries.html
  11. handlebar
    23
    South Florida
    Thanks everyone, I am now enlightened. I am a long time Toyota owner, but this is my first Prius. BTW, I also have a 2009 Camry Hybrid and it has been great.
