What is the MPG penalty of headlights on?
Discussion in 'Gen 3 Prius Fuel Economy' started by Former Member 68813, Oct 11, 2010.
  1. Former Member 68813
    3,524
    981
    US
    I did a search and could not find an answer.
    Thanks!
  2. Joe166
    Joe166 New Member
    720
    96
    South Florida
    I doubt that anyone knows, but I am sure you will still get some answers.
  3. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    There was an older thread on this; I'll suggest my post since it's obviously the best one in the thread, IMNSHO. ;) But there's some interesting additions to my rough estimates in the thread too.
    Bottom line; it's less than 1 mpg. If you're worried about safety, turn them on. A gallon of gas has enough energy to run your headlights for several days continuously.
  4. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Very little impact, but it is why daytime automatic lights aren't offered in the U.S. If it's dark or raining, I recommend using the headlights!
  5. Former Member 68813
    3,524
    981
    US
    Thanks! somehow my search did not find this not too old thread.
    I was not planning to drive without lights after dark (although I saw it practiced in rural Egypt). Rather I noticed my return home commute (after dark) generates lower MPG, but has some elevation change (minor). We are talking mid 60's vs mid 50's. I was not sure how much to attribute to the elevation and how much to lights. I was also curious of the LED lights were cost effective.
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I don't notice much difference with the headlights on but I do find the HV battery runs down noticeably quicker if I have my front fogs on with the headlights.
    Coincidence?
  7. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    The difference will be small enough that you won't be able to get a close to accurate number by comparing overall mpg.
    If you add up the wattages of the lights that are on with the headlights and make some reasonable assumptions about generator and ICE efficiencies, you will be able to calculate the fuel consumed to illuminate the lights.
  8. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    I turned my lights on the minute I picked my car up the day before Thanksgiving 2004 and haven't turned them off since. The reason I did this is because I had a small red car in the land of SUVs and trucks at the time. My last tank I got 50.3 MPG and I live exactly 2 miles from work.
    Oh and BTW I haven't replaced a headlight yet. I replaced an indicator light on the driver's side this past July.
  9. bisco
    49,500
    even tho it may be 1 mpg or less, imagine how that adds up across the country and world!
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    If I remember right, Halogen are about 150 watts/pair, and HID half that amount.
    The least power demand not including lights might be around 5 kw, and a maximum maybe around 20 kw. Think driving 35 mph on a country road with no stops, vs screaming down the highway at 80 mph.
    So, the additional energy use is 5.15/5 for the easy life, and 20.15/20 for the lead foot.
    As you can see, the lead foot wins ;-)
  11. fuzzy1
    10,170
    Give me a distance, elevation change, and round trip average mpg, and I'll give you an estimate of the difference likely attributable to the elevation. This will be based on a rule of thumb of an extra gallon of fuel per 10,000 feet of elevation gain, give or take 10-15%.
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This question is impossible to answer without knowing the speed of the vehicle. Headlights are a fixed load, consuming the same amount of fuel at speed or standing still. At low speeds, the mileage hit from headlights is considerable. At high speeds it is negligible.
    Regardless of speed, 150W headlights are equivalent to 0.2 hp, or 1/5th of a hp. That isn't very much compared to what it takes to move a car.
    Tom
  13. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Here's a fun one for you Tom,
    How much weight would one have to lose in order to make up the 0.2 hp loss due to having the lights on?
  14. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    have you figured in the pressure from the photons pushing against you >
  15. qbee42
    18,058
    3,074
    Northern Michigan
    Good point. We need to factor that in, including the positive thrust from the tail lights.
    Tom
  16. Former Member 68813
    3,524
    981
    US
    Don't forget brake lights, that would explain some cases of unintended acceleration when folks hit brakes!
  17. pEEf
    pEEf Engineer - EV nut
    720
    577
    Berkeley, CA
    Yeah, the Standard Halogens are 55w each on Low. The Taillights and others that come on probably bump it to ~150w. The normal electronics in the car use significantly more than this when the car is Ready.
    I doubt it's effect could be measured in real world mileage tests. (the noise in those measurements is higher)
  18. qbee42
    18,058
    3,074
    Northern Michigan
    I thought about that, but it would be offset by brake drag. How much depends on how hard you press. I suppose if you just gently ride the brake pedal you could get some photon assist. We need to do more testing.
    Tom
  19. Superdrol
    Superdrol Member
    399
    32
    decrease in 0.54389487329572542 mpg
  20. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    It's an easier consideration for EV's. You lose approximately half a mile of range for every hour your headlights are on.
    Plus I didn't think you'd get any thrust from photons, because they're massless?
