What is the part number for this
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by faisalak7, May 31, 2023.
  1. faisalak7
    faisalak7 Junior Member
    46
    UK
    2013 Prius Alpha
    Active
    Hello,
    Just wondering what is the part number for this highlighted in the pictures, mines are ripped and full of oil and dirt .
  2. ColoradoBoo
    ColoradoBoo Senior Member
    985
    654
    Monument, Colorado USA
    Toyota parts have the numbers right on there....I'm seeing a few on there on your picture and if you plug those in a Toyota search engine with your car details, you should find them listed....try McGeorge Toyota or Sparks Toyota. (You may have to buy the entire part to replace that pad, unfortunately.)
    Looks like 51410-15085 and 51410-15095??
    faisalak7 likes this.
  3. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    Thanks , based in UK , if i dont put these foam back will there be any issues ?
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,222
    2,238
    Taylors, SC
    You can't buy just the insulator. Toyota only sells the whole undercover assembly.
  5. Mendel Leisk
    38,874
    For sure you'll need the buy the entirety of what's shown in you picture; the attached fibrous panels are not separate "part".
    And yeah, you could just remove the fiber panels, though it might be slightly loose or rattle? I think they're mostly for sound-deadening?
    Is that yours in the picture btw; if so I'd just let it be, looks not bad.
  6. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    That picture is just from ebay someone selling for £90 the whole thing , i did remove the insulator to wash them they are full of oil and dirt , i thought maybe new ones are easy to come. Any ways i will use the old ones , my only concern was why they are full of oil, maybe during service oil was dropped no sure.
  7. Mendel Leisk
    38,874
    Yeah check underside of engine and transaxle for oil; could be something leaking. If you find something wipe it clean, and next time you're under check if it remained cleaned, or oiliness returned.
  8. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    Thanks will check
  9. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    Search for part number 5141012105 in Rockauto.com It may be the insulation material you may be looking for. Screenshot_20230531_160933_Chrome.jpeg
    #9 xliderider, May 31, 2023
  10. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    Thanks, was just looking for the insulation on top of the sheet as highlighted, the above part number is for the whole thing.
  11. Mendel Leisk
    38,874
    Yeah that’s how it is; the insulation is not a separate part you can buy.
  12. ChapmanF
    15,859
    Toyota parts often have numbers on them with the same 'shape' (nnnnn-nnnnn) as part numbers, that are not their part numbers. Fair warning....
    ColoradoBoo likes this.
