what is the sensor connected to the rear axle beam
Discussion in 'Prius v Main Forum' started by nanchas, Jun 12, 2017.
  1. nanchas
    nanchas New Member
    Ingleside, Illinois
    There is a little stub welded on to the right underside of the rear axle beam. Connected to this stub, with a small bolt, are a couple 2 inch bars that swivel on each other. This is all connected to a plug with a wire that goes up between the muffler and gas tank. It appears to be some sort of sensor. The stub broke, from rust, and the bars connected to it are hanging down. It doesn't seem to be causing any problem. I think I can fix it, but I don't know what it is. Can someone tell me what this is and what it is for. thanks. It's on a 2012 Prius v 5 door hatchback.
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Sounds like a description of a load sensor for the brakes. The system adjusts brake pressure based on suspension loading.
  3. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Load leveling sensor for LED headlights?
    fuzzy1 and xliderider like this.
  4. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    +1, I believe this is correct.
  5. Mendel Leisk
    38,735
    Do you have LED headlight? Our Canadian touring has LED, and also this levelling device, I believe since the LED's are quite bright, with sharp cut off.
    I occasionally shoot a little silicon spray into the elbows and ensure they're moving freely.
  6. RRxing
    2,520
    1,791
    NEPA
    As long as the OP has LED headlights.
    Waiting for OP to return...
    :rolleyes:
  7. fuzzy1
    10,174
    Have you checked the lowbeam headlight aim?
