What is the true maximum SOC?
Discussion in 'Gen 2 Prius Technical Discussion' started by FirstFlight, Jul 3, 2012.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I've been doing some reading on NiMH batteries in the hopes of finding out what the true maximum SOC is. We know that the nominal voltage is 1.2VDC. Just about the entire world agrees with that number.
    When searching for the max SOC, I've seen a few different numbers. They are:
    1. 1.41 VDC per cell (~8.5 VDC per module)
    2. 1.56 VDC per cell (9.36 VDC per module)
    3. 1.85 VDC per cell (11.1 VDC per module)
    I'm not suggesting that anyone states the NiMH batteries should be charged to these value. Perhaps it's a maximum number before the module explodes. I'm not really sure. That last number (1.85 VDC) is really high and is actually called out in a National Semiconductor datasheet. If the Prius modules were charged to that number, the pack voltage would be ~310 VDC.
    Can anyone point me to some type of credible information that shows what the true maximum SOC is
  2. Patrick Wong
    18,200
    6,492
    My personal experience is that the Prius system will allow the batteries to be charged to ~20% above the nominal 7.2V level. At that point, the batteries are at 8.6V and presumably are at ~80% SOC.
    My guess is that 100% SOC would be at around 10.8V per module.
  3. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    My question was pertaining mainly to re-balancing. Using delta peak cut-off is probably preferred but if that option isn't available what would be considered a good voltage to use as a cut-off?
