what is the worst way to drive a Prius?
Discussion in 'Prius c Main Forum' started by priustexasbob, Apr 17, 2017.
  1. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    ok, there have been questions bout best way to drive a Prius, so what is the worst way to drive one?
    I have a short commute, about 4 or 5 miles, I can stretch that to about 9 by taking a different route, mostly feeder road or highway. I can take a third route which would be all city streets. so is this hard on a Prius? would having a faster acceleration than a more sedate one change anything pertaining to health/longevity of the Prius? or a longer drive to work?
    51,689
    the worst way is trying to keep it in ev all the time.
    i would take the feeder roads, accelerate briskly, glide until slowing too much, and repeat.
    don't worry about health/longevity, it was meant to be driven.
  3. fuzzy1
    10,356
    A longer route will boost fuel consumption and wear more than it could possibly improve health-per-mile.
    One member near here has a commute of barely a mile each way. While many of us would walk or bike that, not everyone has the right route or health to do so. Numerous others are in the 2 to 3 mile range.
  4. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    You should be focused on how much gas you're using, not what the best fuel economy is. If your fuel economy is 30MPG for the first five miles, but increases to an overall economy of 40MPG after you drive five more miles, driving those additional miles has caused you to use more gas than if you just stopped after the first five.
    Generally speaking you get better fuel economy by driving slower. When the engine is warm you'll get better fuel economy at 30MPH than you will at 60MPH. But that may not be so true for a short trip where the engine is warming up if driving at 30MPH means a lot of start and stops with the engine running (in warm-up mode) while the car is stopped.
    Since there are so many variables, the best way to answer your question is to just try each different commute a few times and figure out how much gas you used for each. Reset one of the trip odometers at the start of each commute, and at the end look at the miles traveled and MPG. If you traveled 9 miles at 35MPG then you've used 9 / 35 = about 0.26 gallons. Repeat a few times that for each commute and then choose whichever one uses the least gas.
    TheTimob likes this.
  5. Prodigyplace
    12,487
    11,730
    Central Virginia
    Seeing the title i thought the worst way to drive a Prius would be into a tree or off a cliff. :eek: :D
  6. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    I wasn't necessarily referring to getting better mileage, I meant is it better overall for the car/engine to drive 8 miles vs 4?
  7. fuzzy1
    10,356
    I'd say that one 8 mile trip is better than two 4 mile trips. But that doesn't matter for commuting, where doubling the distance won't let you cut the number of trips in half.
    priustexasbob likes this.
  8. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    Longer trips are better for vehicle health overall. I imagine fuel economy may also be better
    roadrunner likes this.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    As others already stated, it isn't a sure thing that driving further is better for your engine. The Owners Manual already tells you what you should do in case of short commutes. With that kind of usage, follow the severe usage maintenance intervals. That means 5000 mile or 6 months OCI instead of 10,000 or one year.
    Raytheeagle likes this.
  10. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    In my opinion you should consider
    EV
    Smart EV you can buy used for 5-7 k $
    And nothing to worry about warm up the engine
    Much less maintenance
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    That would be a perfect commute for a PiP. ;)
    Prodigyplace likes this.
  12. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    My commute went from 30 miles to 3. I was getting 54MPG and averaging 55mph at 30 miles. I'm now down to 41 MPG and averaging 27mph at 3 miles. I'm beginning to think a used electric vehicle may be more suiting now.
    Roqu3 and bisco like this.
  13. bisco
    51,689
    absolutely. have you seen what used leaves are going for? peanuts!
    Colm01 likes this.
  14. jerrymildred
    11,517
    14,147
    Tampa, FL
    I've noticed that. Almost giving them away compared to other hybrid or electric cars with similar miles.
  15. bisco
    51,689
    yeah, if you only need a commuter car, they fill the ticket perfectly.
  16. DKTVAV
    DKTVAV Active Member
    510
    101
    After seeing your low MPG I thought something is off on your car but found out you're driving a V not C.
    My C is doing 45+ at 3.8 miles in winter and 50+ in summer (warm now is SoCal). And when driving 55mph for 16 miles I've got low 60MPG.
  17. Prodigyplace
    12,487
    11,730
    Central Virginia
    A 3 mile commute in Delaware is not ideal for the Prius. The first 3 miles or so take a mileage hit due to engine warmup. It is likely still better than any other non-plugin car with an engine. Perhaps a used PiP would work well.
    Colm01 and jerrymildred like this.
  18. Prodigyplace
    12,487
    11,730
    Central Virginia
    That is Trim V. They used Roman numerals in 2010. It is basically a trim 5 Liftback.
  19. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    My commute to work is 16.5 miles each way, and takes me through rural areas, winding roads, hills, with about 10 stops along the way. My typical route offers many opportunities for spirited driving, when traffic allows it. If I (have to) behave myself, my fuel consumption usually reaches over 60 mpg. However, I love the dynamics of driving and finding the edges of a vehicle's capabilities. This makes my 1/2 hour commute more enjoyable. I will flog my Prius quite hard at times, and yet when I arrive at my destination my consumption is still at 40+ mpg.
    So I'm sure my driving behavior with my Prius is atypical, but am astounded that it still rewards me with amazingly efficient fuel consumption. Some might say my treatment is bad for the longevity of my Prius, but I don't care. A great, fun car!
  20. Sean Nelson
    421
    182
    Well the Prius C wasn't even made in 2010, so it's obviously not a Prius C, which I think was the main point.
