What is this for
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by douglasjre, Feb 19, 2018.
  1. douglasjre
    douglasjre Senior Member
    1,755
    616
    Orlando, FL
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    It’s actually a drain spigot that you can hook up to some of the oil filter housings;).
    Not needed on the Gen3 Prius (at least the ones I have looked at), but on our 2017 Lexus RX450h the oil filter housing is designed to have a central drain removed and the plastic spigot installed. I tried it and it didn’t work so well, as there still was oil In The housing upon removal :(.
    It came with your oil filter purchase:whistle:?
    NutzAboutBolts and tankyuong like this.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,551
    Bay Area
    Those are used for those A3 cartridge filters for Toyota and Lexus vehicle’s. The Prius uses an A1 cartridge filter, so they don’t use that. Honestly, that piece is the most useless piece ever, not worth your time doing it that way. Just my opinion.
    Raytheeagle likes this.
  4. douglasjre
    1,755
    616
    Orlando, FL
  5. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
  6. NutzAboutBolts
    1,476
    1,551
    Bay Area
    Disregard, the Prius uses A6, bigger engine uses the A1.
