What is this for?
Discussion in 'Gen 2 Prius Main Forum' started by Banjoman, Oct 16, 2007.
  1. Banjoman
    Banjoman Member
    124
    Orange County, CA
    Does anyone know what these removable black plates mounted inside the front doors are for?
  2. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    <div class='quotetop'>QUOTE(banjoman @ Oct 16 2007, 01:29 AM) [snapback]526229[/snapback]</div>
    I haven't a clue, but I'm very curious as to why you've decided to uncover one and remove it. What's up?
  3. Banjoman
    Banjoman Member
    124
    Orange County, CA
    <div class='quotetop'>QUOTE(a priori @ Oct 15 2007, 11:58 PM) [snapback]526231[/snapback]</div>
    I discovered these while upgrading my speakers and lining the doors with Dynamat. They make for easy access into the door but look like they're made for some other special purpose. (Not Steve Martin's special purpose from "The Jerk".) :)
  4. Bob64
    1,540
    92
    Virginia
    side re-enforcement in the event of a side impact?
  5. patsparks
    10,664
    567
    Adelaide South Australia
    It looks like they apply pressure to that block of styrofoam to prevent the door skin from drumming. In other words, noise supression. (At a guess)
  6. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    <div class='quotetop'>QUOTE(banjoman @ Oct 16 2007, 03:05 AM) [snapback]526237[/snapback]</div>
    I'm considering the same. Which speakers did you decide on? I was leaning towards the Infinity 6010cs until I saw the poor rating on Crutchfield, but then someone here gave Crutchfield a poor rating <http://priuschat.com/Infinity-6010cs-speakers-t39785.html>, so I'm back in limbo.
    PA P
  7. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    Yep, they improve side impact protection...
    Keith :unsure:
  8. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Oh no, you removed them? Step away from the car...!
  9. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    <div class='quotetop'>QUOTE(firepa63 @ Oct 16 2007, 12:25 PM) [snapback]526399[/snapback]</div>
    <_< :lol: :lol: :lol:
    What was the speaker size? what size can you upgrade to?
  10. Banjoman
    Banjoman Member
    124
    Orange County, CA
    <div class='quotetop'>QUOTE(PA Prius @ Oct 16 2007, 07:00 AM) [snapback]526306[/snapback]</div>
    That's a very long story. I ended up with JL AUDIO ZR650-CSi 6.5" Component Speakers--a bit pricey at $500 to $750--it pays to shop around. The speakers are SUPER GREAT and the tweeters snap right into the JBL mounts. Major problem is power. The JBL amp can't drive them (and many other after-market speakers.) You need to add an amplifier. There are some other issues including where to put the amp, how to combine the front hi & lo signals, how to smooth out the JBL equalization, etc., etc. I posted the following solution for combining the audio.
    http://priuschat.com/index.php?s=&show...st&p=518342
    The best bang for the buck is to install an amp between the JBL amp and the JBL speakers. The Prius JBL system sounds anemic at best. Just pumping up the power makes a huge difference in the sound of the stock speakers.
    Dave
    <div class='quotetop'>QUOTE(patsparks @ Oct 16 2007, 06:38 AM) [snapback]526295[/snapback]</div>
    They don't actually contact the Styrofoam--just kinda suspended in air.
  11. a priori
    3,083
    407
    23
    Chicagoland (West)
    <div class='quotetop'>QUOTE(banjoman @ Oct 16 2007, 12:32 PM) [snapback]526431[/snapback]</div>
    How many bucks for how much bang? And: Where does the amplifier go? (Assuming all you add is the amp.)
  12. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    I had the same question when I dampened my front doors. For sure it's not to hold the white foam thingy in place, because the foam actually is screwed in with big bolts (not sure what for either). In fact, I even took the white foam out and put Damplifier underneath it. You can see the pictures here:
    http://picasaweb.google.com/MagGreyPrius/2ndSkinDriverDoor
    Anyhow, my "guess" on the black thingy is to keep that opening relatively secure. The opening can be used to get behind the inner skin (for maintenance purposes, maybe?). Of course, it's also a source of vibration, so I put Damplifier all over it as well! :)
    banjoman, did you put Dynamats on both skins of your doors?
  13. Banjoman
    Banjoman Member
    124
    Orange County, CA
    <div class='quotetop'>QUOTE(zenMachine @ Oct 16 2007, 10:43 AM) [snapback]526435[/snapback]</div>
    It's a work in progress. The rear doors are covered on the inside skin and plastic door panels. Object was to add mass. Nothing on the outside skin yet. (Should have done this before sealing up the inside :huh: ) On the front doors I plan to cover the outside skin and the inside skin. Already did the panels. I've been re-energized after reading this posted by JonasB
    http://www.sounddeadenershowdown.com/
    Took my trusty Radio Shack SPL meter for a ride yesterday and found a 65dB ambient noise level (A weighted) just driving on a smooth road at 40 mph. It didn't change at 60 mph or when coasting. I think it's noise just from the tires rolling on pavement. Anyway, I'm considering a more aggressive sound deadening project one SMALL step at a time. (Emphasis intentional :p )
  14. Banjoman
    Banjoman Member
    124
    Orange County, CA
    <div class='quotetop'>QUOTE(a priori @ Oct 16 2007, 10:36 AM) [snapback]526433[/snapback]</div>
    After adding a 4-channel (75 watts each) amp, noticed a great deal more and tighter (solid) bass. Cost was about $300. Amp is located directly over the JBL amp under the passenger seat. This is a very handy place for it because of close access to all the wiring you need to deal with.
    JonasB has posted a detailed schematic of the JBL system on the Audio forum. This was my bible for the upgrade--a must have document. You can kinda see my installation here: http://priuschat.com/index.php?showtopic=3...mp;#entry518342
  15. mamerica
    mamerica Junior Member
    31
    Minnesota USA
    Isn't that an access plate needed to replace the window glass?
  16. Banjoman
    Banjoman Member
    124
    Orange County, CA
    <div class='quotetop'>QUOTE(OutOfHere @ Oct 16 2007, 03:27 PM) [snapback]526569[/snapback]</div>
    If it's only an access plate, why all the tooling to shape it to a shape the doesn't even cover the hole?
  17. patsparks
    10,664
    567
    Thanks for correcting me guys, Doh!
    I would think if it isn't against the piece of foam it was added to help with an issue in side impact testing and assisting side airbags to be more affective. I imagine the foam and steel plate are a deformable structure which spread and absorb energy from a side impact. I see the foam is between side intrusion bars.
    Again just a guess.
  18. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(banjoman @ Oct 16 2007, 02:47 PM) [snapback]526551[/snapback]</div>
    What was the sound level before you did the work?
  19. a priori
    3,083
    407
    23
    Chicagoland (West)
    <div class='quotetop'>QUOTE(banjoman @ Oct 16 2007, 05:17 PM) [snapback]526566[/snapback]</div>
    Great! Thanks for giving the whole set-up a complete description and photo-essay. So, for $300 you get a marked improvement in sound, right?
  20. Banjoman
    Banjoman Member
    124
    Orange County, CA
    <div class='quotetop'>QUOTE(a priori @ Oct 16 2007, 07:41 PM) [snapback]526651[/snapback]</div>
    Yes, and maybe even less if you shop for an inexpensive amp (used, refurbished, on-sale, no name.) Check the Audio forum for more ideas and advice.
    <div class='quotetop'>QUOTE(Rick Auricchio @ Oct 16 2007, 07:21 PM) [snapback]526646[/snapback]</div>
    Don't know. Didn't check it. :(
