What is this Part Hanging down???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Borninblue, May 3, 2021.
  1. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    Heard a scraping noise on way home, looked underneath car and this is what I see below...Emergency brake line maybe? Not 100% sure and seeing if it is something I am capable of fixing.
  2. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Yep parking brake cable. Use the other wheel as reference if you need to.
  3. Mendel Leisk
    40,582
    Any recent brake work? Those things don’t disengage easily. You’ll want to slack off the adjuster nut at the parking brake pedal completely, then try to wrestle it back on at the rear. Maybe count threads before loosening the nut, so you can get it back to where it was.
  4. Borninblue
    233
    158
    Cleveland, Ohio
    Thank you, yes had break work done few weeks ago. Would rather try myself then take back. Thank you
  5. ChapmanF
    17,343
    I don't think I've ever fussed with the pedal adjustment to detach or reattach the caliper ends. As long as the pedal is completely released, and you're working at the caliper anyway, there's usually enough slack to be made there by cranking the lever there in the 'apply' direction, IIRC.
  6. Borninblue
    233
    158
    Cleveland, Ohio
    Thanks again, I’ll be climbing under there tomorrow. Hopefully I can get to it without taking tire off? I have some ramps I can back up on, maybe I can get some more room to work.
  7. Grit
    Grit Senior Member
    6,454
    4,186
    Wilkes Land
    easy peasy, lightly press down parking brake, if it doesn’t tighten/engages or makes the usual noise then that’s the parking brake cable.
  8. Mendel Leisk
    40,582
    You can scoot under without raising it. Still, probably much easier with the rear on jack stands and wheel removed.
